4x4/4wd or Pre-Runner TRD?
Discussion in '1st Gen. Tacomas (1995-2004)' started by clicc916, May 8, 2009.
  1. May 8, 2009 at 7:49 AM
    clicc916
    clicc916 [OP] New Member
    I'm new to this board, and looking for a Tacoma. I did a search and found one post relevant to my topic but I need a little more help from everyone else.
    First, I'm looking for a Double Cab model. Second, I want a V6. Third, I will mostly use the truck to tow my fishing (12-ft aluminum) and play boats (17-ft open bow) around--I don't expect to be off-roading too much, and I don't live in a snowy area.
    I just want to know what you guys would recommend, since I can't find a TRD 4x4 double cab in my area. The thread I found recommended the guy get a 4x4 standard and if he wanted the rear locking diff, he could add it on later. Should I feel the same way? I know I won't be using the 4wd often, but it should help me a lot when I'm pulling my boat out of the water. I'm torn.
    Thanks for the help.
  2. May 8, 2009 at 7:54 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I can't say much - cuz I've never pulled boat out of the water.
    But, I would think a Prerunner TRD Offroad with the e-locker would be fine for what you need it for.
    You can add a locker to a non-TRD truck, but you're probably better off getting it upfront & having a warrantee on it.
    Are you looking at new or used trucks?
  3. May 8, 2009 at 7:59 AM
    clicc916
    Sorry, I'm looking for a used 01-04 Tacoma. Thanks for the reply.
  4. May 8, 2009 at 8:04 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    id for thr 4wd just in case u need it
    -ya never know
  5. May 8, 2009 at 8:34 AM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    yeah, a 2wd will pull a boat outta water, but if u could afford it ild go with a 4X4 too!
  6. May 8, 2009 at 8:51 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I think you should go with a 4X4. There maybe more stuff that you might want/need to haul. Maybe, you might want to run a couple trails. IMO, the 4X4 will do good.
  7. May 8, 2009 at 8:55 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I agree the 2wd prerunner will be fine for what you want to do. I used mine to do what you are speaking of and I didn't have a locker.
    But if price isn't an issue I would recommend the 4x4 as some times the boat ramps here are kinda iffy. I was very cautious with my 2wd where I am more relaxed with my 4wd now.
  8. May 8, 2009 at 9:07 AM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    I agree with people on here...for the needs you have explained, a 2wd TRD would work fine. But if you have the extra money and time to wait to find 4x4 in a TRD I would do that. They are out there. I just found a few on CL. You might have to go outside you area but it will be worth it. It is better to have it and not need it than to need it and not have it.
    http://sacramento.craigslist.org/cto/1158086123.html
  9. May 8, 2009 at 11:03 AM
    clicc916
    Funny you mention that post because that's the truck I was mainly looking at.
    Prior to that truck, however, most double cabs I found near Sacramento were either non-TRD or TRD'd Pre-Runners (2wd). Mainly, that's my issue: TRD 2wd or non-TRD 4x4.
    In the past, I used my dad's rwd V8 F-150 to pull the boat, and though it had the power, pulling a watery-boat from a wet ramp was sometimes, uh, challenging due to the lack of traction.
  10. May 8, 2009 at 11:08 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    You got it there, those ramps are sometime slippery as hell.
  11. May 8, 2009 at 12:08 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    your in cali! go 2wd all the way! its way easier to long travel i think its a wiser investment then a 4x4. my front set up has given me alot of trouble.
  12. May 8, 2009 at 2:11 PM
    jeff6001
    jeff6001 Well-Known Member
    San Antonio, TX
    99 trd prerunner
    I have a TRD Prerunner and have pulled a dual jet ski trailer and a 17' bayliner with it and its done fine. Even pulling them out of the slippery ramps. But if you have the cash, get the 4x4 it won't hurt.
  13. May 8, 2009 at 8:16 PM
    Slick8810
    Slick8810 Well-Known Member
    Panama City, FL
    01 Tacoma Prerunner SR5
    3" lift, 20% tint, billet grille
    I wish i had 4wd so i would definitely go for the 4x4 if you can find one. even if its not trd.
