4X4 actuators question.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Huzie11, Nov 30, 2019.
  1. Nov 30, 2019 at 12:46 PM
    Huzie11
    Huzie11 [OP] Member
    2004 Tacoma
    I have been reading all the older forums about losing 4 wheel drive ability. I have a 2004 Tacoma, automatic transmission with the 4x4 switch on the secondary shifter next to the main shifter. It's a push button. So mine recently stopped working. When I push the 4w button in, the light doesn't come on and the truck won't go into 4 wheel drive...BUT, I can hear a piston sound in the front actuator when I push the button in and out. I've read about pulling the Actuator and soldering the point on the tiny motor as well as cleaning inside there, bit if I am hearing movement in there doesn't that mean the motor is actually working? New to the site and not super mechanical but I listen well and would love to hear suggestions on approaching a fix? Thank you.
  2. Dec 1, 2019 at 2:07 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just how did you get to the point it does not seem to work?
    Worked last time you engaged it?? New to you vehicle and this was missed pre purchase??
    Are you sure it is not the bulb is just burned out??
    Do you know for sure that it is not engaging?
    Either you have super hearing or it is very very quiet where you are to hear that move from the cab.
  3. Dec 1, 2019 at 3:27 AM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    If you are sure it is not engaging, start by following wires to connections.. Start at front actuator, may have to move around to the transfer case-disconnect and spray liberally electronics connection cleaner- QD has worked for me. Sometimes oil leaks and time make their way in and do not allow a solid connection. $5 and crawling around
