4x4 advice ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by clawj, Feb 25, 2020.
  1. Feb 25, 2020 at 4:52 PM
    clawj
    clawj [OP] Member
    2017 TRD 4x4 sport
    So this weekend I went ice fishing with my new to me 2017 TRD sport 4x4. Got stuck in very little snow and on some ice, surprising I could possibly get stuck in such little snow. My tires are not great so I will change those for next winter. But my question is.....the guys outside my truck said only 1 front and 1 rear tire were spinning as I was trying to get unstuck. Can anyone give me a brief explanation why all 4 tires don't spin when in 4x4? Thanks
  2. Feb 25, 2020 at 4:56 PM
    puddle
    puddle Well-Known Member
    Kris
    ID
    2020 TRD OR
    Cool dealer placard
  3. Feb 25, 2020 at 4:59 PM
    nathanroyse
    nathanroyse Well-Known Member
    Nate
    2019 Tacoma TRD-Offroad 4x4
    Bilstein 5100 w/ OME 887 Springs Bilstein 5160s TRD Pro Grille Method NVs w/ Falken Wildpeaks 265/75/16
    Better than just 1 wheel drive with a 4x2. Lol. You would think that the computers would know that the wheels are just spinning...
    t0nyvalenzuela and clawj[OP] like this.
  4. Feb 25, 2020 at 4:59 PM
    clawj
    clawj [OP] Member
    2017 TRD 4x4 sport
    So this is normal? Turn the dial on the dash to 4wd and only 2 tires engage ?
  5. Feb 25, 2020 at 5:00 PM
    nathanroyse
    Nate
    Yeah. Since both front and rear diffs are open. TRD Offroad comes with a Rear locker so you get 3 instead of 2.
  6. Feb 25, 2020 at 5:00 PM
    puddle
    Kris
    ID
    2020 TRD OR
    Cool dealer placard
    Yes, I added a video to my original post, kinda explains things
    clawj[QUOTED][OP] likes this.
  7. Feb 25, 2020 at 5:04 PM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    It is normal because most 4x4 vehicles have open differentials as some others have mentioned. If you’re stuck in a bad spot airing down your tires will help provide some extra traction and can help get you in a better position to get out.
  8. Feb 25, 2020 at 5:12 PM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    No no no no no.... while technically that is correct, the traction system should kick in and emulate a locking diff on both axles by applying brakes to the spinning wheel thus engaging the tire getting traction
    You do not need a locking differential for anything but extream off roading
  9. Feb 25, 2020 at 5:14 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Be sure you have some way to air up. Last thing you want to do is drop down in air pressure and then have to get on a highway at reduced pressure.
    whatstcp, clawj[OP] and BSFord like this.
  10. Feb 25, 2020 at 5:19 PM
    clawj
    clawj [OP] Member
    2017 TRD 4x4 sport
    This would make sense. I was trying turning the traction control off ( experimenting what i should do when ice fishing) . So I guess I should not have turned the traction control off and left it on, while in 4H .
  11. Feb 25, 2020 at 5:29 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Good AT tires will help
    clawj[OP] likes this.
  12. Feb 25, 2020 at 5:33 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    AKGSD and clawj[OP] like this.
  13. Feb 25, 2020 at 5:33 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    Try gently applying the brakes while accelerating. It might help you with getting unstuck.
  14. Feb 25, 2020 at 5:42 PM
    clawj
    clawj [OP] Member
    2017 TRD 4x4 sport
    Absolutely agree, basically one month left of winter so at this point for the 1 or 2 more times I may need 4x4 I'll just use the current tires the rest of this winter and thru the summer. Then buy a new set of proper AT tires for next winter
  15. Feb 25, 2020 at 6:04 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    Crawl control might help.
  16. Feb 25, 2020 at 6:07 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    My God... I am glad somebody with some sense answered!
    StayinStock and BSFord[QUOTED] like this.
  17. Feb 25, 2020 at 6:11 PM
    su.b.rat
    su.b.rat broken truck
    welcome to da dumbgeon. kinda surprising folks buy these vehicles w/o a working understanding. i don't even buy$20 stuff if i don't know how it works. thanks for TW anyway.
    hiPSI[QUOTED] and BSFord like this.
  18. Feb 25, 2020 at 6:12 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You do get power to all 4 wheels, at least when moving in a straight line. But if you go around a corner the power will only go to one wheel on each axle. This is necessary because the outside wheels have much farther to travel around a corner than the inside wheel. They need to be able to turn at different speeds.
    In certain extremely low traction situations, like ice, the axle thinks you are going around a corner and will send power to only 1 wheel on each axle. Unfortunately the one with the least traction.
    There are several ways to help. Most newer vehicles come with traction control which will use the computer to gently apply brakes to the spinning wheel. This tricks the axle into sending power to the other wheel, the one hopefully with better traction. I'm surprised a 2017 didn't have traction control. Did you have it in low range? On some vehicles traction control shuts off in low range. You can also gently apply the parking brake to achieve the same thing.
    Some trucks have a limited slip axle in the rear. This senses wheel spin and will attempt to send power to the other wheel. Many newer trucks now come with a locking rear axle. You flip a switch and the rear axle locks both wheels together. This is fine for getting out of a jam, but shouldn't be left on, this is for temporary use when you're really stuck. If you turn a corner with it locked on a dry hard surface you risk breaking stuff.
    Any of those tricks will get both rear wheels turning, but you'll still only have one on the front. There are a handful of vehicles available with a locking front axle and some guys do it aftermarket. But it is one of those things that if used in the wrong setting will break expensive parts.
    FWIW, I've been driving 4X4's for over 40 years. I've only had one truck with a limited slip axle and 2 with a locking rear diff. And none prior to 2007. I managed to do just fine without them. Only used the locking diff twice since 2007. Driving skill still trumps gadgets.
    clawj[OP] and Thunder Fist like this.
  19. Feb 25, 2020 at 6:14 PM
    BSFord
    2018 TRD Sport 4x4
    :hattip:
    hiPSI[QUOTED] likes this.
  20. Feb 25, 2020 at 6:22 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    This isnt exactly emulating a locking diff. Probably something closer to a limited slip diff.
