4x4 and Manual Swap a Double Cab Prerunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by marcostacos, Jun 15, 2023.
  1. Jun 15, 2023 at 1:06 PM
    marcostacos
    marcostacos [OP] Member
    Hi everyone.
    I am going to swap my 2002 prerunner with the 2.7 to manual and 4x4.
    I have a 99 xtracab donor truck with the 2.7
    I have a couple of questions for those who did the swap:
    1: Is the crossmember compatible from the 4x4 manual truck to the auto prerunner? I read some comments saying you have to cut and weld, other say you can just swap the crossmember because just the transmission mount is different. I would just like some confirmation on this.
    2: I have a j-shift transfer case with the ADD hubs, I would like to retain this as I want to use 2wd on the highway outside of winter to have better MPG. Is it possible to retain the ADD? Every thread I have seen on the swap had a manual hub conversion.
    Those are the 2 things that are blurry for me and clarifying this would make the swap alot more straightforward in my head!
  2. Jun 15, 2023 at 3:03 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  3. Jun 15, 2023 at 3:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You can absolutely keep ADD as this combination was offered in both the Tacoma and 4Runner. What you're seeing is the 'easiest' version of said conversion since J-shift and manual hub setup will be all mechanical.
    J-shift transfer case will have a 12V out signal (I think it's 12V) to communicate and tell your vehicle it is in 4x4; you'll get the cool light on your dash not to mention your actuator will engage.
    What's important to know is whether you have an actuator from a 95.5 - 00 or 01 - 04 as the early variants are vacuum actuated, later variants are electric.
    Bivouac likes this.
  4. Jun 15, 2023 at 3:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You know this swap better than anyone :luvya:
  5. Jun 15, 2023 at 4:52 PM
    Madjik_Man
    Colorado Front Range
    Will a j-shift transfer case from an 04 auto work with a 5MT swap? Or is there something with the output shafts that would need to be changed?
  6. Jun 16, 2023 at 7:16 AM
    marcostacos
    So it seems I have a vacuum actuated TC since my truck is a 99. I will try and narrow my research to that.
    From a quick research, this is what I found: 1st gen Transfer Case Identifcation for Replacement / Swap | Tacoma World
  7. Jun 16, 2023 at 7:28 AM
    Madjik_Man
    Yeah I have that post saved. And have read GearCrucnchers and several swap threads.
    I just never saw a definitive answer to my question. I have an 04 auto with a j-shift transfer case with ADD and ABS brakes.
    Would this swap onto an R150F?
    The first time I asked this question is because in my 98 xtra cab (manual trans) the gear shifter is on the left and the transfer case shifter is on the right.
    In my 04 auto, the transfer case shifter is on the left.
  8. Jun 21, 2023 at 7:46 AM
    marcostacos
    Anyone got an answer to my crossmember related question?
  9. Jun 21, 2023 at 9:53 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I believe the 1st gen crossmember stays the same for manual and auto in extended cab and double cab. I believe @Speedytech7 swapped a manual for an auto. He should know for sure.
  10. Jun 21, 2023 at 9:54 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    As long as it's a V6 the the crossmember stays in the same place
    Madjik_Man likes this.
  11. Jun 23, 2023 at 7:11 AM
    marcostacos
    I have a 2.7
  12. Jun 23, 2023 at 9:10 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Can't you get under both trucks with a measuring tape and determine how far back the cross member is from the engine or some other point of reference (on both trucks) and compare?
    If the cross members are in the same location on both frames, then you'd know you can just swap cross members or bolt up the manual trans to the existing cross member (in the double cab truck).
    Bivouac likes this.
  13. Jun 23, 2023 at 9:30 AM
    marcostacos
    That was my plan if I didn't get an answer. I don't have access to the parts truck for the next month though so I wanted to plan ahead so that I could have everything figured out when the time came for the swap.
  14. Jun 23, 2023 at 10:49 AM
    Red_03Taco
    Jerad
    Maybe take the measurements on your double cab, then post them here, and ask for the same measurements from a TW member with Xtra cab 2.7 4WD, MT truck. I'd help take measurements from mine if it weren't V6.
  15. Jun 23, 2023 at 8:16 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    The crossmember is the same. But the automatic is 3" further back than the manual. Also the mounting bracket is different between the crossmember and the transmission.
    Bivouac likes this.
  16. Jun 23, 2023 at 9:52 PM
    Bazooka1
    Bazooka1 Active Member
    96 Tacoma
    Interested In this thread
  17. Jun 27, 2023 at 6:56 AM
    marcostacos
    So let me get this straight. With the v6 you don't have any fab work to do since the crossmembers are in the same spot. Just reuse the manual one.
    However on the 2.7 you need to remount the crossmember 3 inches forward and reuse the manual one.
    Did I get this right?
