4x4 and towing
Discussion in 'Towing' started by shrimperman, May 22, 2009.
  1. May 22, 2009 at 3:53 PM
    shrimperman
    shrimperman [OP] Member
    I have a 03 taco v6 automatic double cab with weight distribution hitch,brake controller ,sway bars and tranny cooler.I am going to be towing a travel trailer weighing approx.4000lb.Im new to the towing scene so should i tow in 4x4?Should i put it in low gear going down steep grades?Will i encounter any troubles towing 4000lb?Im i lil nervous and hoping i got everything in order b4 i attempt to tow.I will have to go through some steep mountains for about 45 mins .
  2. May 22, 2009 at 4:01 PM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    I've never heard of towing in 4WD unless on uneven/slippery terrain. If you're on the highway, 2WD will do it.
    It's wise to use engine braking to rduce reliance on the Taco's brakes. The brake controller works with a gyroscope inside that detects vehicle movement, so if the truck slows by using engine braking, the trailer brakes will come on.
  3. May 22, 2009 at 4:51 PM
    shrimperman
    Thanks for info,,,when you say wise to use engine braking im assuming your that it would be wise to put in low gear going down steep grade??
  4. May 24, 2009 at 12:05 PM
    petersharp
    Louisville, CO
    Yes, to stop the truck and trailer gathering speed.
  5. May 24, 2009 at 12:09 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I would not tow in 4wd unless it is to get started on slippery ground but once going on paved road 2wd should suffice. Only in the rice fields do we use 4wd to get going.
  6. May 24, 2009 at 5:58 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    the only time i used 4wd when towing was to take a boat out of a steep dock. other than that, 2wd will do. Not to mention that driving in 4wd on dry pavement will ruin your diff
  7. May 24, 2009 at 6:32 PM
    shrimperman
    THE 4000 lb shouldnrt be a prob???????????
