4X4 Bad at highways speeds?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTLTaco, Dec 4, 2010.
  1. Dec 4, 2010 at 4:38 PM
    MTLTaco
    MTLTaco [OP] Well-Known Member
    Montreal
    09 Double Cab TRD
    Roads are getting slick up here especially in the mountains. Is it bad to use 4 Wheel Drive for long distances and at highway speeds?
  2. Dec 4, 2010 at 4:40 PM
    moulin6801
    moulin6801 Well-Known Member
    YES, you should not go over 50mph on 4x4
  3. Dec 4, 2010 at 4:41 PM
    brow
    brow Well-Known Member
    Andy
    Minnesota
    2020 Dodge Ram 1500
    in the manual it says something like max 62mph with 4wd-hi. Also I don't have any real info on this but i tend to only switch the 4x4 on on highways when I'm in really bad parts, and switch it off right away if the road improves
    SilverBulletII likes this.
  4. Dec 4, 2010 at 4:42 PM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    my owners manuals always said not to go over 50 in 4 hi
  5. Dec 4, 2010 at 4:45 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    You would be amazed with today's electrical safety doo dads how good you have it. I drive in 2wd 99% of the time this past storm and I felt perfectly comfortable doing it. I only switched into 4HI to get moving at an intersection. If I had weight in the back I probably would have not even needed to switch it into 4HI.
  6. Dec 4, 2010 at 4:47 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    if the highways are bad enough that you feel you need 4wd, you shouldn't be going highway speeds. generally 4wd is only useful when getting up to speed. as soon as your cruising it isnt doing anything but causing unnecessary wear and tear to your drive-train and could actually be more dangerous due to the under steer it causes.
    winkel likes this.
  7. Dec 4, 2010 at 4:49 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    If the roads are so slick that you need to engage 4WD why would you even be driving at highway speeds?
    winkel likes this.
  8. Dec 4, 2010 at 6:32 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    ^^this... slow down if the roads are that bad otherwise you'll be like all the other jackasses flying down the highway in 4wd and end up in a ditch. 4wd doesn't do anything on ice.
  9. Dec 4, 2010 at 6:43 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    2017 Tacoma Dbl cab long bed.
    Hood Strusts, remote Start, truck came with Leveling kit and wheels.
    don't drive in 4LOW doing 55 MPH.. I know a guy who did that.. his engine is now blown.
  10. Dec 4, 2010 at 6:56 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    No, I believe it is fine. I use my 4wd whenever the roads are inclement. That's what its here for
  11. Dec 4, 2010 at 7:29 PM
    OffroadToy
    Dam!!:eek: I'm surprised he even got over 20 mph in 4LO.
  12. Dec 4, 2010 at 8:04 PM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    on my way back to NM I hit snow in Flagstap of AZ . I turned 4wlow at 60MPH and drove at 70MPH on snow for over an hour without problem at all . You can switch to 4wlow at max 62MPH and drive as fast as you can but on the 4whi you have to fully stop and switch to 4whi and can only drive max 25MPH . That what I heard from my merchanic . He worked for Toyota for 25yrs.
  13. Dec 4, 2010 at 8:13 PM
    yan
    yan Well-Known Member
    Colorado
    06 CC TURD!
    Sanga I think u have it backwards lol
    OG_Tacoma likes this.
  14. Dec 4, 2010 at 8:15 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    How about people just look it up in the truck manual. It's all spelled out there. My book page 178.. Then maybe reread your posts.
    Now does your posts make any sense still ?
    My truck Auto 5 speed if you can get in to shift into 4th you can go 118 MPH in four high. Only 46MPH in four low. Anyway I used to shift my truck into 4 high in the fall and shift it back out in the spring and I never had a problem ever. Some places you need it some places you don't, some places you need it all winter long.
  15. Dec 4, 2010 at 8:25 PM
    MTLTaco
    Montreal
    09 Double Cab TRD
    Thanks for the feedback fellas
  16. Dec 4, 2010 at 8:43 PM
    Trap
    Indego Ink TRD OR
    The only thing that could screw it up is good traction in 4 hi. You have to be in dirt or snow for 4 hi. Bare dry pavement is bad news for four wheel drive. The wheels have to slip a bit in 4 wheel drive. If the traction is too good to slip you can't be in four wheel drive.
  17. Dec 4, 2010 at 8:52 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    you have that backwards. 4low is for towing.. you always drive in high and 4high is just turning on 4x4.
  18. Dec 4, 2010 at 9:43 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Wow... the spray of (mis) information scares me here sometimes!
    1) Don't you have this card in you visor (or an owners manual)?
    NOTE that it tells you to keep speed below 60 mph when shifting into H4 (High Range 4WD). Not the max. speed in 4WD...
    In high range, it can be the most you want... as long as the road surface is NOT DRY PAVEMENT. Seriously, if you are able to drive a pickup that fast in bad weather... should you?
    2) Those of you with newer models ('09+ and some earlier ones): Don't you have this light and a button with the same graphic?
    This is VSC (Vehicle Stability Control) and is amazing at stopping your truck from spinning out of control during sudden steering changes at speed. This feature pretty much takes away the need of 4WD on wet paved roads for handling safety. It is on in H2 and H4 normally... and even if you turn it off it can come back on if your truck is about to get into a wreck... Built by Bosch, and called the greatest advance to driving safety since the seat belt!
    Final note: L4... is a LOW gear ratio for crawling up down or across difficult terrain, slowly (like less than 30 mph)... It is not for 'towing' unless you are off roading over the conditions I just described.
    Off Road Tacomas also have a Rear Differential Locker... for emergency conditions to get out or up or over something that standard 4WD low range can't.
    '09 + Off Road Road Tacomas have A-TRAC in L4 and that provides the traction of front and rear locking differentials, without the limit to emergency use only.
    Andretti34 likes this.
  19. Dec 5, 2010 at 12:59 AM
    sanga700
    San Diego, CA
    yep your right , just come out and double checked .
  20. Dec 5, 2010 at 1:17 AM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    Bro, as long as your under 50 ish when you shift into 4WD your good no matter how fast you go. As long as your in 4Hi. Think about it. Everything in your system is moving that fast if you are in 2WD.... Just dont turn your wheels too much while hauling ass.
