4X4 Bad at highways speeds?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTLTaco, Dec 4, 2010.
  1. Dec 5, 2010 at 5:21 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks. Reading the first page of this thread I was thinking WTF , nobody knows 4 sure. Go left, no go right, no go what ever way you want to, huh ? Thanks for the ray of sunshine.
  2. Dec 5, 2010 at 5:32 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I run 4WD on the highway when its pouring rain out but I never go over 60mph. I do it mostly just to run 4WD and keep things moving/lubricated (so to speak). Haven't had a problem yet.
    I will say, I've never engaged it at that speed. I always engage it on the on-ramp before I'm up to speed.
  3. Dec 5, 2010 at 5:50 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    David K's got it right....those numbers are the shift speeds, not the max.
    You should take care at highway speeds in 4wd, but I don't agree with the guys who say you shouldn't go highway speeds in 4wd. My argument is that a truck has very little weight over the drive wheels in 2wd and is actually less stable in bad weather than a FWD car with the weight of the engine over the drive wheels. Therefore, flipping into 4wd actually allows me to safely maintain highway speeds in conditions that make my truck less stable but not necessarily a car. However, I do agree that 4wd is not an excuse to go at breakneck speeds on the highway, it just helps to safely maintain a reasonable speed.
  4. Dec 5, 2010 at 3:29 PM
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    to the OP: 4 wheel drive doesn't help you stop any quicker in a slippery situation. If I feel I need 4WD I usually drive a bit below posted speed limits.
  5. Dec 5, 2010 at 3:33 PM
    mmadej87
    mmadej87 Mayday
    NMB, FL
    98 Xcab Prerunner
    i had read this article with something about gear box wind up? anybody know how true this is?
    i will try to find where i read this...
  6. Dec 5, 2010 at 3:37 PM
    mmadej87
    mmadej87 Mayday
    NMB, FL
    98 Xcab Prerunner
  7. Dec 5, 2010 at 3:42 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Just hang on for a while and reed your statement again.
    Take care
    vbibi:(
  8. Dec 6, 2010 at 3:52 AM
    Janster
    Jandy
    Lancaster, PA
    It's not about stopping, it's about staying in control. It's about using 4WD to your advantage to help you stop, steer, & drive in a controlled manner on slippery conditions.
  9. Dec 6, 2010 at 7:27 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    ON the 7th winter now... Just got back from 40 miles of Lake effect snow covered mess. I've got 1000's of miles locked in 4hi driving hwy speeds.
    Seeing the O.P. is in Quebec, most people have snow tires and generally know how to drive in winter. You should have no issues maintaining hwy speeds in 4hi if the conditions are safe to do so.
  10. Dec 6, 2010 at 7:40 AM
    Graham
    Graham Pay it Forward
    Western New York
    2005 4x4 TRD Black V6 6 speed manual
    55 or lower in 4 hi
  11. Dec 6, 2010 at 8:17 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    You can go as fast as you want in 4HI, just keep it below 60MPH while shifting from H2 to H4.
    Remember, 4 wheel drive does not equal 4 wheel stop.
  12. Dec 6, 2010 at 9:14 AM
    Janster
    Jandy
    Lancaster, PA
    I disagree.
    4WD helps you maintain control. For instance - utilizing engine braking is better with 4 wheels slowing the vehicle down than with only 2 (prevents fishtailing). Also, while driving and making turns, the front wheels help drive you into the turn versus plowing into the turn. Aside from preventing you from fishtailing through out your travels in the snow.... 4WD does A LOT more than just for 'low traction' situations.
  13. Dec 6, 2010 at 9:27 AM
    SmilingMark
    SmilingMark Well-Known Member
    Mark
    Ogden, UT
    2010 Access Cab
    Color matched grill w/ grillcraft. BHLM and Morimoto Mini HID's Debadged.
    /\ this
    I drive in snow alot. If I'm not comfortable in 2WD, then I'm certainly not comfortable going over 60MPH. And vis versa, if I'm confident enough to be going over 60, then the roads should be in good enough shape for 2WD.
    Note that card in the truck says "KEEP" vehicle speed under 60. I read that to mean keep it there, Maintain speeds lower than 60.
    While I'm sure you're not doing any damage going faster than that, what's the point?
  14. Dec 6, 2010 at 9:48 AM
    Janster
    Jandy
    Lancaster, PA
    4WD or even 3WD (referring to your arguement) is still better than only 2WD for controllability. I'd rather have all 4 wheels engaged & driving and allow my pedal control & physics do the rest.
    2WD, a good set of tires, and a lot of gas + momentum will overcome the 'traction' issues but 2WD (Rear wheel drive) SUCKS in any slippery conditions for 'controllability'.
  15. Dec 6, 2010 at 9:50 AM
    #35
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  16. Dec 6, 2010 at 11:04 AM
    #36
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Yes it does and here's why. With 4WD you're sharing the power and torque with the front wheels. If the back is inclined to slip out the front still has traction and the power going to those wheels will help pull the truck in the direction you intend. Additionally, because you are sharing the torque and power, there is less likely hood for the rear to slip out because you are halving the power to the slipping wheels.
    All this combined equals increased steering and responsiveness and increased stopping if utilized with engine braking as Janster mentioned.
    That being said, I used 4Hi for my 2 hour highway commute in really bad slush snow weather, and I was cruising at double what I would have normally if I was in 2Hi.
    Also helped that I was following a Semi who was putting nice ruts in the road for me. :D
  17. Dec 6, 2010 at 11:49 AM
    #37
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Well yeah that is correct... While NOT under power, braking and steering will respond exactly the same in slippery/wet conditions. I can assure you of that. At that point it all comes down to the tires. I think you guys were simply answering different questions with correct answers.
  18. Dec 6, 2010 at 1:07 PM
    #38
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    lol ..... when i was in high school we went wheeling about 7 miles south of my house and i got my dads 90 bronco stuck in 4low, had to drive home down the freeway (only way home, no frontage roads out there) at 35 mph with the hazards going ..... needless to say he was pissed .... cant remember what the reason it got stuck was, the truck had a manual transfer case with manual hubs
  19. Dec 6, 2010 at 1:18 PM
    #39
    lrak
    lrak Well-Known Member
    4wd will make understeer worse. 4wd will however drastically reduce severe oversteer. If you hit a slick spot on an onramp in 4x4 you're not likely to merge onto the highway sideways. That is easy to do while accelerating in a curve with varying traction (black ice, hit a slush rut, etc) in a RWD vehicle with a light rear end. I've had two responsible middle-aged co-workers total their pickup trucks that way.
  20. Dec 6, 2010 at 5:14 PM
    #40
    mmadej87
    mmadej87 Mayday
    NMB, FL
    98 Xcab Prerunner
    not sure about the 6spds, but im sure the manual says not to engine break...(atleast for auto trannys)
