4X4 Bad at highways speeds?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTLTaco, Dec 4, 2010.
  1. Sep 19, 2020 at 8:30 PM
    #61
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    You're right. I just checked that. Thanks :thumbsup:
    I just corrected my response.
    crazysccrmd[QUOTED] likes this.
  2. Sep 19, 2020 at 9:10 PM
    #62
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You're fine
  3. Sep 20, 2020 at 9:41 AM
    #63
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Use 4x4 on gravel roads, forestry roads at 50-60mph with no problems.
    ImMrCrash likes this.
