4x4 Binding - Likelihood of Damage :/
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shortbus47XYY, Oct 11, 2018.
  1. Oct 11, 2018 at 12:39 AM
    Shortbus47XYY
    Shortbus47XYY [OP] Well-Known Member
    Central Rockies, Colorado
    2017 TRD Off Road
    I did something really stupid and learned a hard lesson. I'm hoping to draw on everyone's experience to determine what the chances are that I have severe damage lurking, and/or to find out what signs I should be looking for that may indicate substantial damage.
    Here's the rundown. I was driving the truck in 4x4 on slick Colorado high mountain roads and failed to take the truck out of 4wd after I got off the highway, where the roads were only wet (definitely not slick). As you can expect around 2-3 sharp turns and when I went to park I experienced bucking and skipping as the truck tried to throw the front wheels around to compensate for the difference in speed.
    So yeah, I blew it. Unfortunately every vehicle I have owned before this has been a permanent 4 wheel drive (cruddy unreliable Landovers haha). As dumb as it sounds it really didn't occur to me what was actually happening until I rolled down the window and watched the wheels as I parked and thought oh s#&%, it's shoving the front wheels sideways. The physics that causes this is not foreign to me, but I stupidly did not realize they made 4x4s without center diffs (*serious facepalm*). I feel much shame...
    So what I'm wondering is how much damage I can expect or if this is something I should be stuffing all my spare cash in a piggy bank over. Obviously I realize this is not something to be doing again. Unless I'm in my buddy's truck of course!
    Overall there was noticeable bucking on about 4 occasions. I pushed through each of them "tenderly", at around 5-10mph and the lowest possible revs that got the truck to move. The only noise this made was the tire squeal. I did not hear anything under the truck. Also, it did go back into 2wd with just a mild clunk. And later back on the ice slick it went back into 4wd no noises, then back into 2wd when the road got dry again. Thanks everyone!
  2. Oct 11, 2018 at 12:47 AM
    bzzr2
    bzzr2 Well-Known Member
    Don't worry, your truck will be fine!!!
  3. Oct 11, 2018 at 12:49 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    You're probably ok, but you can damage your CV, front diff, or xfer case.
  4. Oct 11, 2018 at 5:25 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    is it still under warranty? the dealer would have to prove you did something wrong if they didn't cover it..but I would push it if its under warranty.
    Shortbus47XYY[OP] likes this.
  5. Oct 11, 2018 at 5:34 AM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Honestly, I wouldn't worry about it. I'd be shocked if there was any damage at all.
  6. Oct 11, 2018 at 5:50 AM
    Enfield1
    Enfield1 Well-Known Member
    Brad
    Bryan, Tx
    '18 White DCSB OR 4wd auto
    This. It's more robust than you might think. You will most likely be replacing a CV before a transfer case.
  7. Oct 11, 2018 at 6:04 AM
    WorKinJoB
    WorKinJoB Well-Known Member
    Drew
    2017 Tacoma Sport 4x4
    OME lift, 887, Dakar packs 265 70 17 duratracs Snugtop GB sport
    Were you in 4 Hi? I’m assuming you were if you were doing interestate/highway speeds. As stated above, the CVs are what take the beating on hard pack. I know it’s not the most ethical thing to do but If you are worried, take it to the dealer and tell them the 4x4 is popping or making noises. If they find something let them fix it. If they don’t have them make a report on it so when warranty runs out you have a case if it shows back up.
  8. Oct 11, 2018 at 6:10 AM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    I did this once when truck was new. Took a couple of sharp turns when it wasn’t quite slippery enough. I’m now at 45k with no issues.
    896Down and Shortbus47XYY[OP] like this.
  9. Oct 11, 2018 at 1:19 PM
    Shortbus47XYY
    2017 TRD Off Road
    Thanks to everyone for the insight. A lot of great information here, from everyone! It's nice to know the systems are, or at least are supposed to be, more robust than I figured. Thanks Enfield1, Beer:30, bzzr2, gulzeb, and comatose for that perspective.
    To answer some questions from above I did have it in 4 hi, fortunately I did know better than to take a high speed jot ride in low range. Also, I do think the truck is still under warranty. It's only at 30k miles...
    Sounds like my best course of action is just to keep an eye out for anything unusual and avoid a repeat. If I hear anything I'll be sure to bring it in as kgilly and WorKinJob advised. Otherwise I'll bring it in for a look next chance I get before I wait out the warranty. Thanks again.
  10. Oct 11, 2018 at 1:27 PM
    Shortbus47XYY
    2017 TRD Off Road
    On this same topic I was talking to a buddy of mine who actually has a bit of experience with his part time 4x4, and he mentioned that in our weather conditions he usually leaves his truck in 4x4 even on wet pavement if the conditions are below freezing, and will just remember to switch back on the off ramp and does not take tight turns or go flying. He says he tries to keep it no faster than 65.
    This sounds appealing to me because up here the high rockies it's pretty common to be on wet surface and go around a shaded corner where a few inches of snow and ice will pop up unexpectedly. But as stated I'm experienced with cars that tend to break anytime that you use them outside of how they were designed, so I don't know how rough this would be on the taco.
    What do you all advise?
  11. Oct 11, 2018 at 1:35 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    My 2 cents, and what I do in Maine, add a couple hundred pounds of tube sand over the rear axel. 4x4 hi only if shit gets real squirrely
    gulzeb and Shortbus47XYY[OP] like this.
  12. Oct 11, 2018 at 2:06 PM
    Enfield1
    Brad
    Bryan, Tx
    I can't comment on ice or snow, lol.
  13. Oct 11, 2018 at 2:38 PM
    Mark_H
    Mark_H Well-Known Member
    Loveland, Colorado
    2018 4x4 DCLB TRDOR Tacoma
    Cement w/ Tech & Premium Packages
    Umm...what am I missing here? Is everyone saying you shouldn't put a vehicle into 4Hi on anything other than sheets of ice? Here in CO you could drive to work in a blizzard and drive home on dry roads...I've left many 4x4 (w/ manual transfer cases) vehicles in 4Hi on dry roads for days on end.
  14. Oct 11, 2018 at 2:44 PM
    phsycle
    phsycle Well-Known Member
    CA
    Why? Binding or not, that's completely unnecessary.
    SR-71A, gulzeb and Shortbus47XYY[OP] like this.
  15. Oct 11, 2018 at 2:51 PM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    No, I don't think any of us are saying that. If the roads are clearly dry, I'm going to be running in 2H. If roads are wet with ice patches, I will run in 4H until I get to where I'm going or until the roads become dry. Back in the day of manual locking hubs and a manual shift transfer case, I'd generally lock in the hubs and leave 'em locked all winter and just shift the TC in and out of 4H on the fly as needed.
    SR-71A and Shortbus47XYY[OP] like this.
  16. Oct 11, 2018 at 3:01 PM
    Shortbus47XYY
    2017 TRD Off Road
    That makes sense. So what I'm gathering is probably not a big deal if the roads are wet and cold and the risk is there, just take it off before going into tight turns or when the road dries up. That seems pretty doable...
  17. Oct 11, 2018 at 3:12 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    You didn’t damage anything... this is a common test to perform actually. You engage the 4Hi, and turn the wheel slightly on the pavement. The popping is the truck trying to bend from the power being at an angle and the grip of the tires. The frame bends ever so slightly and snaps back in to place once the tires break free. I used to do this on used trucks when shopping for them. It’s a good indicator that the four wheel drive works. The trucks I bought for that company went on for years and years of hard use on back country and mountain roads.
    Literally nothing on your truck is broken. They are designed to take much more abuse than a slight flex on pavement.
  18. Oct 11, 2018 at 3:15 PM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    Yep, that's pretty much it. What's going to vary between drivers is their 2WD vs 4WD comfort level. For some, they'll have to be clearly losing traction before shifting into 4H, while others will get in as soon as there's the slightest hint that the roads might be slick. There's no right answer. Just do what makes sense for you and try not to do anything that causes binding. A little binding now and again like what you experienced likely won't cause any damage, but I wouldn't go making a habit of doing it. Driving down a dry freeway in 4H isn't going to hurt anything, but as the poster above me stated, there's no reason to do that.
