4x4 binding
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moledigger, Jan 20, 2019.
  1. Jan 21, 2019 at 1:41 PM
    CanadianYeti
    CanadianYeti Well-Known Member
    Kitchener, Ontario,Canada
    2014 TRD DCLB
    Excellent post! I wanted to get into the math but didn’t have the time. Good on you!!
  2. Jan 21, 2019 at 2:11 PM
    vwbuggsy
    vwbuggsy Well-Known Member
    Clinton, MD
    09 DC 4X4 LB Black Sand Pearl
    N-fab steps, Wet Okole Covers, line-x, tint, vent shades, budget stereo upgrades, weathertech floor liners
    I think you meant that for 96cardboard. I'm the one that doesn't quite know what's going on, LOL.
  3. Jan 21, 2019 at 2:43 PM
    CanadianYeti
    2014 TRD DCLB
    Oops yeah. Got interpreted while I was posting lol
    96carboard likes this.
  4. Jan 21, 2019 at 3:49 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Side to side difference will put wear on the center diff as the spider gears will have to turn at different speeds, can be done with open diffs, but should not be done for a long time.
    Front to rear difference will put wear on the tcase when in 4wd as the tcase has to turn both drvshfts at the same speed.
    In 4wd on hard surfaces you have to account for the difference in tire diameter, the front tires will be smaller than the rear because there is more weight over the front tires. Like 69carboard said the difference is small but over miles becomes a big difference.
  5. Jan 21, 2019 at 3:53 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    I've had driveline bind up on an AWD car with different tread amounts and an AWD suv bind up with a tire that was about 5psi low.
  6. Jan 21, 2019 at 6:19 PM
    vwbuggsy
    Clinton, MD
    I'm not sure what could be done about it, but they all just seems like a major design fail at least I anything worth permanent AWD. In real world conditions, shit like that happens. Even with our tpms you could easily have a tire low that doesn't cause the light.
    So... How about this. Drive the truck in 4wd for a few miles a month in a straight line on rainy days? That should lube up the pavement enough right? At least with my shitty tires that really do not do well in rain!
  7. Jan 21, 2019 at 7:52 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    40399K miles on my truck and I only engage 4x4 in the dirt. Why anyone would do this while driving at 50 to 60 mph on the street is unbelievable to me. I have no problems with my trucks 4x4 system.
  8. Jan 21, 2019 at 8:05 PM
    12valve
    12valve Active Member
    2012 sport 4x4 shortbed 6spd
    Snug top, airbags, abs kill switch, yellow wire, greased frame no rust, popnlock, 265/75r17 duratracs, 2wd low
    Put it this way, if you can engage 4x4 on pavement at 50mph straight stretch of road or hell even slight corners and the 4x4 disengages when you put it back in 2wd the driveline isn’t bound up. It won’t disengage 4x4 if the driveline in binding.
  9. Jan 22, 2019 at 5:46 AM
    96carboard
    96carboard Well-Known Member
    This is to do with difference in axle averages.
    I.e., if the average diameter of the two front wheels is 30" and the average diameter of the two BACK wheels is 30 1/8".
    Moderate side to side differences are irrelevant, since you have a differential on both axles.
  10. Jan 22, 2019 at 5:47 AM
    96carboard
    NO NEVER!
    Your STOPPING (front) tires should be the ones with the more meat on them!
    But remember that ANY variation in the average tread depth from front to back will result in binding while in 4WD. Simple way to mitigate that problem is to never use the 4WD on hard surfaces.
  11. Jan 22, 2019 at 5:50 AM
    96carboard
    Yes it will release under moderate binding, but it will POP or BANG when the tension is released.
  12. Jan 22, 2019 at 6:28 AM
    96carboard
    Not sure who wrote the manual that suggested a monthly use of 4x4 "to lubricate", but it is nonsense and completely unnecessary. Whether the 4WD is engaged or not, the front parts are still going to move a bit, and that is more than enough to keep everything nice and lubricated.
  13. Jan 22, 2019 at 7:35 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    The manual states we can engage/diengage 4wd up to 50 MPH. I’ve slowed on the highway to 50-55 (with no one close) to either go into or out of 4wd during and after snow storms. The Tacoma has a light rear that gets squirrely in 2wd in slippery conditions.
  14. Jan 22, 2019 at 8:20 AM
    Mully
    CA
    On a snowy road is not a problem. Take care.
    PzTank[QUOTED] likes this.
  15. Aug 8, 2024 at 11:57 AM
    #35
    bootsonlvblvd
    bootsonlvblvd Member
    2022 Army Green SR5 Trail Edition
    Audio: Infinity Reference Speakers Exterior: TruXedo TruXport Tonneau Cover Tailgate Remote Lock Bed Lights
    Thank you very much for a detail response. I learned something new today!
  16. Aug 8, 2024 at 12:36 PM
    #36
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    To avoid the bang/clunk when disengaging... while moving in 4H before turning the switch back into 2WD take foot off gas pedal so there's no load/bind on the driveline- then turn switch back to 2WD.
