4x4 Binding?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdtemple, May 30, 2010.
  1. May 30, 2010 at 9:53 PM
    jdtemple
    jdtemple [OP] Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    First things first. I am a new 4x4 owner, have very little seat time driving in 4x4 mode. Everyone has to start some where. So here is my issue.
    I was going down some uneven dry dirt steep hills. While going down hill I was riding the brake and correcting the wheel position to counter the uneven "Steps".
    Downhill uneven road diagram!
    While doing that I could hear what sounded like a binding as I was applying the brakes. I let off and the sound stopped, but I was going faster than I wanted to. I noticed it more in 4low than 4high.
    Everything seems fine. On flat ground I was able to shift into/out of 4h and 4l, and no unusual sounds in 4h or 4l while on flat dirt trails. I just don't want to hit the trails again and have it fail because I screwed something up and didn't catch it. I still have a lot to learn.
    Edit to add : Followed all proper shifting according to the manual.
    2nd Edit : Auto Transmission on 33" wheels. I heard the sounds, felt it in the wheel a little bit.
  2. May 30, 2010 at 9:57 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    Wait so you tried to switch into 4WD while moving?
    If so read your manual, I think you have to be in neutral or park and you have to be at a full stop.
  3. May 30, 2010 at 10:00 PM
    jdtemple
    Bay Area CA
    My issue was not with shifting, followed the manual for that. My issue was once I was already shifted and moving.
  4. May 30, 2010 at 10:03 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    That's interesting...
    You'll have to wait for the smart people to chime in...
    Ive never had this happen to me
  5. May 30, 2010 at 10:03 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    you can switch to 4H while moving...you have to be stopped to switch in and out of 4L
  6. May 30, 2010 at 10:44 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    You should only feel 'binding' when you have the fronts turned real sharp in 4hi/lo... it feels bad but is totally normal, just avoid doing it on dry pavement.
    If you can, try going straight down those same "steps" instead of 'slaloming' the steps. The only thing in your situation that alerts me is the "correcting the wheel position to counter the uneven "Steps". " IF it wasn't doing it otherwise then I bet the 4x/t-case is fine, just how it works.
    I'd be much more concerned with any bad noises: grinding, ping!ing, etc. Binding is pretty normal.
  7. May 30, 2010 at 10:52 PM
    joes06tacoma
    Joe
    Central Coast, CA
    If you were on the brakes, you might have felt the antilock kicking in. I believe it still works in 4hi, but not 4lo. Someone else here may be able to tell us for sure.
    Were you in 4hi? 4lo and first gear will give you a lot more control. Ideally if you are going downhill on a loose surface you would use the low gears to slow you down, not the brakes. If you feel the truck start to slide while descending, you can actually give it some gas to get the wheels rolling again.
    Edit: I just re-read your post and saw that this happened in 4lo as well. Not sure what to tell you, 4lo should rarely require braking unless you are on some crazy inclines.
  8. May 31, 2010 at 12:41 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    If in 4Lo and you heard some whining sound, that's the transfer case with the gears going to town. That sound is normal.
  9. May 31, 2010 at 6:58 AM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Might be your ABS kicking in, as stated above. Happens whenever I press the brakes off road.
  10. May 31, 2010 at 7:02 AM
    Brunes
    Brunes abides.
    Rotorhead
    If it was a dry dirt down hill...I would wager you might not even need 4x4. Photos of the trail would help...
    You said you HEARD it...but did you FEEL it?? The nose of truck wiggling or bucking?? Vibration in the wheel?? Is your truck manual or auto?? What size are your tires??
  11. May 31, 2010 at 11:37 AM
    jdtemple
    Bay Area CA
    Thanks for all the replies, I have edited the thread up top with more info. I could have been ABS, or maybe I was just turning the wheel too much. Wish I took some photos.
    Imagine driving straight down a 45 degree (Just a number, no idea how steep the hill actually was) hill with alternating speed bumps on each side of the truck. Drivers side goes over bump 1 and as it dips down passenger side goes over bump 2, basically rocking the truck from driver to passenger side.
    Based on replies I am not going to worry to much, just try to avoid the situation again and learn more about the need/use of 4w4.
  12. May 31, 2010 at 12:32 PM
    nvdeserted
    Reno, NV
    I know exactly what kind of bumps you are talking about. Very common on high traffic/eroded hills. Just go straight through them; you'll likely get a wheel off the ground but it's ok, you'll have 3 still on the ground. Straight, slow, smooth, no prob.
    IF you do need to steer a little, some binding feeling is normal... as much as possible try to always go straight down declines, turning chenges where gravity wants you and can cause a roll over at worst. Put it in 4lo too, no need for the ABS screwing with you on a technical drop.
  13. May 31, 2010 at 6:49 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Sounds like your ABS was kicking in.
