4x4 clicking left front in 4WD, suspension knock/pop
Discussion in 'Technical Chat' started by brown84, Oct 5, 2014.
  1. Oct 5, 2014 at 10:47 PM
    brown84
    brown84 [OP] Member
    Colorado
    09 TRD Sport DC Long Bed
    3" OME suspension lift
    Hi, I'm new to the site and recently bought a used 09 TRD Sport double cab long bed with a 3" OME lift. I'm trying to learn as much as I can by searching here, talking with other Taco friends, and learning the repair manual. Thanks in advance for any help.
    The truck has been fine since I bought it in August. Last month I took it off roading here in Colorado and it performed well in 4HI and 4LO, in mixed conditions. Today I took it on an easy offroad trail that only required 2WD, but tried to shift into 4HI just to be safe. I am concerned because when in 4HI or 4LO, a clicking/ticking noise is coming from the left front area. The noise happens when driving with the wheel turned both left and right; but it doesn't make the noise when driving straight. Can anybody please help me diagnose the problem?
    Perhaps related is another suspension knock/pop noise I get also in the front left area. That usually happens when I hit a sudden bump at high or low speeds. It sounds bad, and only on the left front side. If you can imagine driving abruptly over a pothole (large or small), and hearing a loud knock/pop from the left front suspension. The noise also happens a lot when on washboard roads with larger washboard bumps. The right side is solid/good.
    I'd appreciate any advice from others on the forum. If there are any Toyota/Tacoma mechanics near Glenwood Springs, CO, I would be interested in getting a reliable mechanic.
    Thanks, Brown84
  2. Oct 5, 2014 at 10:50 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Possible CV joint seized up maybe, how are the ball joints?
  3. Oct 5, 2014 at 11:03 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Is the popping/clicking/ticking present just in 4x mode ?? If so more than likely you're CV has issues, check your CV boots & look for about a ton of grease slung all over hell too, this would indicate CV boots are torn , have leaked out all the lube & the tripod/tulip joint is dry as hell & most likely shot, usually once they start making noise, you're time & $$ ahead by just replacing the CV shafts with OEM or equivelent
  4. Oct 5, 2014 at 11:11 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    What Doug says ^^^
  5. Oct 5, 2014 at 11:22 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    What David says I said^^^^^^^^^^^:)
  6. Oct 6, 2014 at 11:51 AM
    brown84
    brown84 [OP] Member
    Colorado
    Thanks guys. I'll take a look later, borrowing the lady's car.
  7. Oct 6, 2014 at 11:53 AM
    brown84
    brown84 [OP] Member
    Colorado
    The ticking is in 4wd only. The suspension knock/pop is all the time if I hit a bump abruptly.
  8. Oct 7, 2014 at 12:19 PM
    David K
    What happens if the CV axle boot rips is the grease all flings out (and dirt gets in)... either way, the parts go metal to metal without the grease barrier, wear, other bad stuff, and then makes the knocking or clicking noises you describe... as 4WD Doug says! ;)
  9. Oct 10, 2014 at 5:40 PM
    lemons
    lemons LOCO 4X4
    Virginia
    07 TRD DC Offroad 4X4
    Icon coil overs W/King 14 inch 700lb springs and super bump bump stops, Allpro Expo leaf springs, Allpro Ubolt kit W/timbren Bump stops, Dif Drop Kit, Magnaflow Cat-Back Exhaust, Badges painted Rust-Oleum bed liner, Color Matched TRD Sport Grill W/Grille Craft Insert, TRD seat covers, Weather Tech Floor Mats, Flyzeye's , fog light anytime mod, ABS Off mod, ATO skid plates, ATO rear H/C bumper, BAMF sliders w/kick out, CBI front bumper, Engo 10000lb winch, Rigid D2 foglights, Piaa 510 fog lights, cobra CB w/firestix antenna, AFE snorkel
    ^^^ what they all said about the cv... I also have had some odd pops and knocks come from my front suspension when hitting potholes, and turning sharply at slow speeds. This started after getting the front end aligned, turns out they didn't torque the LCA to spec. I tightened it up and it stopped. might want to try that too.
