4x4 Computer
Discussion in '1st Gen. Tacomas (1995-2004)' started by GA1044, May 30, 2009.
  1. May 30, 2009 at 11:15 PM
    GA1044
    GA1044 [OP] Well-Known Member
    San Marcos, TX
    2002 trd 4x4
    Air Hog, Grey-Wire Mod, Fabtech Coilover 3.5 Lift, Deck Plate Mod, Rear Diff Breather Mod, Magnaflow Exhaust
    Well after some good exploring and some headaches, i think i have found the problem, it might be the 4x4 ecm is not givin the locker enough juices since it was submerge in water/mud. any1 know where i can get one asap. the truck is a 2002 tacoma trd DC thanks in advance guys
  2. May 31, 2009 at 6:37 AM
    GA1044
    San Marcos, TX
    2002 trd 4x4
  3. May 31, 2009 at 6:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Im not sure its the computer....Check the harness that plugs into the axel. Could be something in there causeing the issue?
  4. May 31, 2009 at 10:41 AM
    GA1044
    San Marcos, TX
    2002 trd 4x4
  5. May 31, 2009 at 2:39 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Yeah I would check the wiring for maybe corrosion, ohm check the harness or check the computer voltage output at the computer harness compared to the locker harness
  6. May 31, 2009 at 8:33 PM
    GA1044
    San Marcos, TX
    2002 trd 4x4
    corrosion check(lots of it) the voltage is 4 instead of 12,
