4x4 conversion guide with images?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Monster47, May 29, 2020.
  1. May 31, 2020 at 4:52 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    I did this conversion on my Prerunner a few years ago at the same time i did a 6" lift. Actual conversion parts cost me around 2k which included custom 1 pc rear driveshaft and lengthening the front because I opted to use the inchworm adapter(discontinued) method which saves you 700-800 bucks. The adapter allows you to convert a 2wd trans to 4wd but pushes everything thing back about 2 inches further than stock which explains the custom driveshafts. I also used the manual FJ xfer case. If you're mechanically inclined you can do this conversion. If not then either stick with the 2wd or trade it cuz you'll be paying more in labor costs than in parts if you have someone else do it. Keep in mind that when you do decide to buy parts make sure the front ifs is the same gear ratio as your rear or else you wont be going anywhere in 4wd.
    ohcaltexscar, t.hornstra and DG92071 like this.
  2. Jun 1, 2020 at 8:28 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Im doing it right now and im on pace to spend about $2,800 with everything including oils and seals
    I had to regear the front diff so mine added an extra $750 FYI
    DG92071, MA_TACO and cubie like this.
  3. Jun 1, 2020 at 8:52 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    If resale value matters, I’d never buy a converted 4x4.
  4. Jun 1, 2020 at 8:58 AM
    MA_TACO
    Wesley Chapel, FL
    I'll never sell it :D
    DG92071 likes this.
  5. Jun 1, 2020 at 9:01 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I think it's ironic that people buy the most reliable truck and tout it's longevity, but constantly bring up resale value. I don't really care about resale value personally cause I'm never planning to get rid of it. I'd be more concerned about resale value on a Chevy cause I'd need a new one every 5 years.
    DG92071 and Brian422 like this.
  6. Jun 1, 2020 at 9:03 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    i dont think anyone who is even considering a 4x4 conversion would ever sell their Tacoma
    will.i.was and DG92071 like this.
  7. Jun 1, 2020 at 9:03 AM
    DG92071
    DG92071 Well-Known Member
    If function and reliability matter I'd never buy a factory 2nd or 3rd gen Tacoma 4wd.
    Tacomas have killer resale values and I'm positive a converted 2wd would get equal to or more than a 2wd. Mods don't ever make the same amount of money that is put into them when new products are used.
  8. Jun 1, 2020 at 9:42 AM
    TheDevilYouLove
    Marylandistan
    Interesting, I did not know that factory 4x4 Tacos were so unreliable. You should consider working for Toyota so that you can train their engineers.
  9. Jun 1, 2020 at 9:54 AM
    DG92071
    You must be a Toyota engineer to be so offended.
    I never wrote they are "so unreliable", I wrote that there are many flaws in Toyota Tacoma factory 4wd systems. Read a thread or two here on TW about them.
    t.hornstra likes this.
  10. Jun 1, 2020 at 10:37 AM
    TheDevilYouLove
    Marylandistan
    Not offended one little bit, just amused. Have a great day :thumbsup:
  11. Jun 1, 2020 at 11:33 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Stock 4x4 electronics like the add and rear actuator fail fairly often. With the kind of water crossing we do here on a daily flooded basis, all of my friends change their electronics at least twice a year.
    Swapping to FJ manual transfer case and keeping the front end live 24/7 with gx/t4r jackshaft tube is the way to go!
    DG92071 likes this.
  12. Jun 1, 2020 at 12:02 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    How I envision conversions like these.
    TheDevilYouLove likes this.
  13. Jun 1, 2020 at 12:10 PM
    jowybyo
    Joe
    Baltimore, MD
    In reality, it's closer to this:
    EDIT: actually might be more like this:
    ajohnson likes this.
  14. Jul 20, 2020 at 4:05 PM
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
