4x4 Conversion Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5amStevens, Feb 23, 2020.
  1. Feb 23, 2020 at 9:43 AM
    5amStevens
    5amStevens [OP] Well-Known Member
    Gilbert, Arizona
    2000 Tacoma 4x4 Prerunner TRD
    I'm currently converting my 2000 prerunner Xtra cab. Will a 3rd gen 4runner 4x4 rear drive shaft fit an Xtra cab taco?
    Thanks,
  2. Feb 23, 2020 at 9:49 AM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    The 4runner’s are shorter. You can use the front driveshaft if they are both out of the same transmission types. Manual to manual or auto to auto.
  3. Feb 23, 2020 at 9:51 AM
    5amStevens
    Gilbert, Arizona
    Ok thanks. I already have the front. There are just a ton of 4runners where I live and no Tacomas. Ill just have to keep looking. Thanks again.
  4. Feb 23, 2020 at 9:55 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Get yours custom lengthened at any shop that does work on drive shafts.
    Heck, put it in 4x4 without the rear shaft in that way you can get to said shop in fwd. Then when you get it cut down, install it and you've got your rear drive wheels back.
  5. Feb 23, 2020 at 9:59 AM
    5amStevens
    Gilbert, Arizona
    I
    I called the shop near me and they want $150 to shorten and balance which doesn't seem to bad but there is a guy who parts out 4runners and he wanted 50 bucks for the full rear drive which is seems pretty cheap.
