4x4 Conversion questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Will Prerunner, Mar 23, 2011.
  1. Mar 23, 2011 at 4:27 PM
    Will Prerunner
    Will Prerunner [OP] Well-Known Member
    Tempe Az
    01 TRD Prerunner Doublecab
    Trail-Gear rock sliders, OME Lift, kobalt tool box, herculined fender flares, CrossFab light bar, Deck plate Mod, Differential Breather Extension, 32"goodyear duratracs Pioneer 3 way speakers, alpine head unit, Boss Bass 600 sub, custom az pinstriping
    Going to start slowly collecting parts for the swap. No solid axle or anything just 4x4 IFs. I have a 2001 DoubleCab Automatic V6. Ive got a couple questions though before I start. ttorra may be a better spot to ask but I figured I'd try here first since I'm a member. Any help would be appreciated.
    1.What year range tacoma and 4runner will work for the transmission and transfer case? I will probably end up using 4 runner parts as they seem to be easier to find.
    2. Can i use the transmission out of a 2.7 or does it have to be the V6? I have heard conflicting answers.
  2. Mar 23, 2011 at 4:30 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Steps for 4x4 swap:
    1) Trade prerunner in on a 4x4.
    2) Done.
  3. Mar 23, 2011 at 4:35 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Wasting your time imo but go for it if you want the hassle. Post a lot of pics.
  4. Mar 23, 2011 at 4:40 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    I agree with the above. The cost of labor and parts is more than what you loose on a trade in. Have you looked into an arb locker? You will be surprised what a locked 2wd can go through
  5. Mar 23, 2011 at 5:15 PM
    thegame
    thegame WUT?
    Brian
    Bay area
    01 Prerunner -> 4wd IFS -> Dana 60 SAS
    I completed a 4wd swap on my 01 double cab V6. I found a transmission/transfer case from a 97 4Runner for $350, free 4.10 front diff, complete manual hub setup with spindles, CV's, hubs for $300, front portion of a rear driveshaft from a 4wd model for $100 and front driveshaft for $100. Add in some replacement parts for ~$300 like ball joints, a u-joint, driveshaft balancing, manual hub seals, studs etc. After selling my prerunner transmission for $350, I think I completed the swap for under $1000. Factoring in how much I paid for the truck and how much cheaper insurance is, I'd say it's a worthwhile swap to do.
    If you are a DIY kinda person, I say go for it. It was a bit of work and had I known about different dipstick lengths between the 2wd and 4wd transmissions, I would have been driving the truck a couple days after tearing it apart and I did all the work myself.
    It makes the swap easier if you install all manual parts; hubs and transfer case. That way you aren't messing with wiring up the ADD system (which isn't that hard either). Any V6 auto transmission (A340F) will work in your truck whether it be from a 96 4runner or a 02 Tacoma, just make sure you get a transmission with a kickdown cable, not an electronic one. All mechanical kickdown cables came on 96-02 transmissions, 03-04 transmissions have an electronic kickdown cable and it won't work in your truck without tearing the entire transmission apart.
  6. Mar 23, 2011 at 5:29 PM
    Will Prerunner
    Tempe Az
    I payed 7k for the truck the cheapest dblcab 4x4s run 10k I know damn well i can do it for under 3k Prob around 1500
  7. Mar 23, 2011 at 5:30 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    this
    dilemma solved
  8. Mar 23, 2011 at 5:32 PM
    Will Prerunner
    Tempe Az
    Thanks the thegame that what I needed to know
  9. Mar 23, 2011 at 5:35 PM
    Will Prerunner
    Tempe Az
    I think I can do it for 1500 then I still have 500-800 worth of old parts plus I am attached to my truck
  10. Mar 23, 2011 at 5:38 PM
    rex99
    TArdCOMAWORLD
    Proton Cruiser
    very true, theres even "Similar Threads" at the bottom of this page that prove this
  11. Mar 23, 2011 at 7:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Bingo! A few folks have done it for 1000 bucks or less. Some pay a little more, and go SAC, or get some lockers, etc.
  12. Mar 23, 2011 at 7:06 PM
    jandrews
    Have fun then. Post pics.
  13. Mar 23, 2011 at 7:20 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    If you are a do it yourself kinda guy go for it and also knowing some people helps a lot too
  14. Mar 23, 2011 at 7:22 PM
    01tacoprerunner
    01tacoprerunner 16 TRD OR Inferno/01 4WD Prerunner
    Brian
    Raleigh, NC
    Wrong:p
  15. Mar 23, 2011 at 7:23 PM
    01tacoprerunner
    Brian
    Raleigh, NC
    If Chris4x4 says it can be done for under $1000 the rest of yall just hush.:D
    The 4wd Auto transmission for the V6s and the 4 cyls are the same. Just differnt bell housings all are A340 F or E idk one letter is for prerunners and the other is for 4wds
  16. Mar 23, 2011 at 9:07 PM
    thegame
    thegame WUT?
    Brian
    Bay area
    Just shop around for good deals and look for people parting out vehicles. Post wanted ads for what you need (usually little stuff or anything really). It may take longer to complete but you'll have spent less money on the swap. Don't forget little stuff like bolts that hold the front diff in place or the proper dipstick for the tranny, be very thorough and think of EVERYTHING. Hell, picking up a FSM and looking at diagrams would help a lot too.
