4x4 conversion!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Offroadtaco, Mar 31, 2013.
  1. Mar 31, 2013 at 5:52 PM
    Offroadtaco
    Offroadtaco [OP] Active Member
    08 PreRunner SR5
    Cobra 29 LTD Classic CB Radio, Fire Stick 4ft antenna, A.R.E. Campershell, 12in sub with JBL amp, Rear bumper tow loops.
    Ok I've done so much research I'm starting to get irritated. I have a 2008 tacoma sr5 prerunner. I want to do a 4x4 conversion but need a complete parts list. I get its easier to go and trade it in but time and money is not and issue right now! I love my truck too much to get ride of it so it is worth it to me to do a conversion. So someone please just give me a straight answer of what it would truely take to do the conversion. Thank you. 4clyd, 4x2, no locker,5 speed manual trans. Need more info just ask.
  2. Mar 31, 2013 at 6:07 PM
    Jux
    Jux :D
    Northern Colorado
    2013 V6 4x4 SW DCSB TRD OR
  3. Mar 31, 2013 at 6:14 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    They've been building one on Tacoma magazine. I'm pretty sure they have the parts list. It's a free digital magazine, found it here on Tacoma world, pretty cool, and the tech article on 4x4 conversion was done well! Sorry I don't have the link.
  4. Mar 31, 2013 at 6:17 PM
    Jux
    Jux :D
    Northern Colorado
    Here you go
  5. Mar 31, 2013 at 6:18 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If money isn't an issue, I'd trade for a V6 4x4 and spend the time building it up from there.
  6. Mar 31, 2013 at 6:21 PM
    Offroadtaco
    08 PreRunner SR5
    Thanks you guys this is exactly what I wanted! I'll keep everyone updated when I start the conversion
  7. Mar 31, 2013 at 6:24 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    best bet is to find a donor 4x4 unless you're ok with shelling out what the dealership wants.
    need;
    front diff
    front cv axles
    front 4wd wheel bearing hubs (think you can get them fully assembled)
    forward driveshaft (front diff to transfercase)
    either a 4wd trans or inchworm adapter to mount the transfercase to the prerunner trans (the trans is identical except for the length of the output shaft)
    transfercase + front bellhousing to mount the case to the trans (could look into manual fj case conversion via rocksolidtoys)
    4wd y-pipe or custom fab
    4wd trans cross-member or custom fab
    rear driveshaft (transfercase to diff)
    4wd ecu
    4wd additional wiring
    *note* I think most trucks come pre-wired for everything, I haven't had time to fully take my dash out to be sure, but i've found a bunch of tapped off connections with pre-wired switches.
    you will need misc tools and other hardware(bolts,screws,washers,etc)
  8. Mar 31, 2013 at 7:16 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Good luck on the conversion. For me, that's a big undertaking.
    I'm looking forward to the build thread. :thumbsup:
  9. Mar 31, 2013 at 7:24 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    ^^^^^all the same truck. only one documented person has completed this. Wyatt of Rocksolid toys (awsmdc on tw).
    the main difference between the 2wd and 4wd that seems to be difficult is the transmission crossmember. they are not located in the same spot on the truck. so a new one has to be fabbed up.
    if you do complete this. go with the fj case swap. then u dont have to mess with the 4wd ecu but you will need to wire in a switch for the add actuator on the front diff
  10. Apr 1, 2013 at 9:54 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    If you buy all the parts from Toyota it might up being cheaper to keep your truck and buy a 4x4 Tacoma.
  11. Apr 1, 2013 at 11:00 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I'm no engineer but it seems the most straightforward way would be to do a solid axle swap.
  12. Apr 1, 2013 at 11:40 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    X2 this is what I wana do cuz if your gunna spend the money and can't find a doner truck just go all out
  13. Apr 2, 2013 at 7:23 PM
    Offroadtaco
    08 PreRunner SR5
    Now let me ask this. I have the 2.7l four cylinder, with the five speed manual trans. Is that powerful enough to power the conversion plus if I wanted to tow a tent trailer?
