4x4 driving questions/concerns
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sirsethro, Mar 6, 2013.
  1. Mar 6, 2013 at 8:18 PM
    #41
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just curious... why do you feel the need to engage 4WD on dry pavement? :confused:
  2. Mar 6, 2013 at 8:57 PM
    #42
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    A couple of things..
    1) 4WD in the snow yes, as mentioned, the front pulls you where you want to go.
    2) 4WD on pavement .. as long as your not turning it's fine. Personally I wouldn't but it won't break anything if you keep it straight.
    3) Oz is old, yes.
    4) 4LO to pull a tractor on solid ground, no turning? Sure, use the torque, that's what it's there for.
    5) Marklar .. I missed something somewhere.
    6) You should engage 4WD for 10-15 miles every month.
  3. Mar 6, 2013 at 9:00 PM
    #43
    BradyT88
    BradyT88 Well-Known Member
    I would worry about the possibility of destroying an axle or ring and pinion trying to pull a tractor/trailor... Now if it were just a tractor you would probably be ok, but the 2nd gens with the factory lockers like to occasionally blow up their R&P under just their own weight...
  4. Mar 6, 2013 at 9:07 PM
    #44
    Fightnfire
    Marysville, WA
    I watched a 2nd gen pull a loaded CT bus up the hill in snow/ice. 4 LO and take it easy.
    Different video:
    Why would they use a chain ... but it works.
    http://www.youtube.com/watch?v=3l638ymlsrA
  5. Mar 6, 2013 at 9:37 PM
    #45
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Were you in 4wd in your sig pic? Looks like you could bust a rear ring and pinion gear if you had the locker on, maybe worse cause you were jumping your truck the front cv's could break also?!
    I'm just saying your telling these guys what not to do with 4wd and here your jumping your truck. I do like the pic by the way looks badass. There's lots of good points on here, I'm not talking $hit just saying to each their own.
    Thanks
    Brett
  6. Mar 6, 2013 at 9:46 PM
    #46
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I gotta start carrying recovery straps. I cant wait to pull someone out of the sand :D
  7. Mar 6, 2013 at 10:09 PM
    #47
    bullaculla
    Da big big island!
    now why would you do that? :p
  8. Mar 7, 2013 at 7:11 AM
    #48
    BradyT88
    :rofl: you have a point. I'm not saying you should never pull the guy, just that I would be cautious pulling a tractor/trailer. I blew up my factory ring and pinion on stock tires on a regular paved road. 4.88's seem to be stronger. Guy in the video is on soft ground so that would allow wheel spin and prevent major damage.
    And yes I was in 4wd in my pic. Long travel guys jump their rigs all the time and a lot harder than I was so ring and pinion and CVs were the least of my worries. Haha more like shocks, motor mounts, mounting points, frame etc... haha
  9. Mar 7, 2013 at 7:50 AM
    #49
    sde780
    sde780 Well-Known Member
    You don't need a dirt/gravel road...just don't make turns!
    My truck is much more stable in 4x4 driving above 40 MPH in the snow. Can power through slides - in 2WD the traction control gives me severe understeer which I don't like.
  10. Mar 7, 2013 at 8:01 AM
    #50
    BradyT88
    Yeah... I have a switch to fix the traction control issue.
  11. Mar 7, 2013 at 8:03 AM
    #51
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Everybody has a switch to fix the traction control issue
  12. Mar 7, 2013 at 8:12 AM
    #52
    BradyT88
    You guys and your fancy factory switches... haha. 05 never came with one. On that note doesn't the traction control re-engage once you go over like 30 mph no matter how long you hold the switch?
  13. Mar 7, 2013 at 8:12 AM
    #53
    OZ-T
    Peter North
    British Columbia
    No
  14. Mar 7, 2013 at 8:14 AM
    #54
    OZ-T
    Peter North
    British Columbia
    To clarify , the VSC / Traction Control is always there in the background , push and hold the VSC button for 3-5 seconds and it is turned " off " and stays " off " at all speeds , however it is actually just greatly reduced in sensitivity and will not kick on unless you get seriously out of shape
  15. Mar 7, 2013 at 8:18 AM
    #55
    BradyT88
    Sounds good enough to me. I have no idea just have effective our VSC is at correcting our vehicles in really bad situations, but honestly if I were to have something happen doing high speeds on the freeway I think I would trust it more than my reflexes at those speeds.
  16. Mar 7, 2013 at 8:19 AM
    #56
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I don't :)
  17. Mar 7, 2013 at 8:20 AM
    #57
    OZ-T
    Peter North
    British Columbia
    You have VSC / Traction Control ?
  18. Mar 7, 2013 at 8:20 AM
    #58
    BradyT88
    Do you even have traction control? haha I thought '06 was when they added the disable switch to those that had the traction control systems.
  19. Mar 7, 2013 at 8:24 AM
    #59
    Pugga
    Massachusetts
    Nope :)
    Thus... no switch (note the use of a word that is actually supposed to have a 'u' in it :boink:)
  20. Mar 7, 2013 at 8:25 AM
    #60
    OZ-T
    Peter North
    British Columbia
    Problem solved , thanks for coming out , next
