4x4 effects on driving
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoRover, May 11, 2017.
  1. May 11, 2017 at 1:26 PM
    TacoRover
    TacoRover [OP] Member
    2012 Tacoma TRD
    Hi TW,
    2012 TRD Sport Crew Cab, Long box, automatic transmission.
    I have a few questions regarding 4x4 engagement.
    1) Last winter, I did a two hour, round trip, twice. Once was 4x2 and the other was in 4x4. I noticed nearly identical gas mileage, with 4x4 potentially being a little better. That's doesn't make sense to me, but I'm wondering if there should be a difference between the two and I would think 4x2 SHOULD have the better mileage, should it not?
    2) What are the effects of 4x4 on the driveshaft? The reason I ask is, accelerating in 4x2, I sometimes get a "bump" in shifting at some of the shift points. It's sporadic though. In 4x4 this doesn't happen, or at least not nearly to the extent and I'm wondering if it's drive shaft related? Perhaps needs some grease?
    Looking for thoughts on these two points as I've pondered both of them.
    DukesTaco likes this.
  2. May 11, 2017 at 2:42 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    1. How different? The actual mileage difference between the two driving conditions is probably less than the margin of error of your calculation
    MadDaddy likes this.
  3. May 11, 2017 at 3:08 PM
    Snotrocket
    Snotrocket Well-Known Member
    Maine
    2022 TRD OR DCLB
    It probably won't make much of a difference in mileage. Even when you're in 2wd all the front axles are still spinning.
    On the older pre Tacoma trucks with locking hubs I would get a decent mpg increase with my hubs unlocked.
  4. May 11, 2017 at 3:48 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    1. likely no change in gas mileage as its affected by so many other things.
    2. in 4x4 you get far less axle wrap as the front wheels pull you forward, this is why the bump is reduced.
    127.0.0.1 likes this.
  5. May 11, 2017 at 7:24 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You should not be using 4X4 for 2 hour road trips. Unlike AWD vehicles 4X4 was designed to be used OFF ROAD. It is OK to use it for brief periods in ice/snow on pavement, but only long enough to get moving from slick spots or up inclines. While driving at speeds of up to 60mph or so won't damage anything, driving on pavement will at any speed. If it is safe to drive at speeds over 25-30 mph operating in 4X4 is if anything a disadvantage. People who do this is why I'd not buy a used 4X4 vehicle. While you may not have broken anything yet, that 2 hours on the road has caused premature wear and damage to your transfer case. It will fail much sooner than it should.
    All things being equal you WILL see a reduction in fuel mileage operating in 4X4. But I'm betting road conditions were much different on the trip you made in 4X4 and your driving style was much more cautious. Speed kills fuel mileage.
    DukesTaco and stairgod like this.
  6. May 11, 2017 at 7:29 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    No, just no. Maybe you just worded it weird but this is bad advice to the OP.
    4x4 Tacomas get worse gas mileage than 2x4 no matter what because of additional weight and that's all. It's total BS that you shouldn't drive in 4x4 except for brief periods of time and only buying NEW 4x4s??!? Alright dude. Guess someone has to pay the sticker... carry on
    DukesTaco, BrokenMech and 02Duck like this.
  7. May 11, 2017 at 7:33 PM
    TireFire
    Olympic Peninsula
    OP, the reason people are saying not to use 4x4 all the time is that Tacomas do not have a center differential. That means if you are in 4wd torque is split evenly (50-50) between front and rear axles and during turns your front wheels travel much further than the rears. On slippery surfaces such as snow, ice or dirt this is fine because the wheels can just skip thru but on very grippy surfaces such as dry pavement it can cause the driveline to bind up which does cause premature wear and tear.
    Taco Nation and knottyrope like this.
  8. May 11, 2017 at 7:42 PM
    Marshall R
    Marshall
    none
    Anytime you have more components moving you create more resistance.
    All things being equal a 4X4 operated in 4X2 gets virtually the same fuel mileage. But all things are rarely equal. Most 4X4's get worse fuel mileage because they are 200-300 lbs heavier because of the extra running gear, they have larger tires with poor rolling resistance and the higher stance catches more wind. The more mods and accessories added makes it worse. Keep them stock, use the same tires and you won't see 1/2 mpg difference.
    Here is a good link explaining why not to operate in 4X4 on pavement. Toyota does not do a good job of explaining this in their owners manual. Most of the other manufacturers offer stern warnings. They all use the same systems, the transfer cases are built by the same vendor on almost all of them.
    http://4x4abc.com/4WD101/def_turnpart.html
  9. May 12, 2017 at 4:10 AM
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    I put at least 10k miles on my truck running in 4wd the last 2 years, it also snows 8 months out of the year. Never heard of ruining a 4x4 system by using it. I always get a slight loss while in 4wd and the winter gas doesn't help either.
    TacomaMike37 and BrokenMech like this.
  10. May 12, 2017 at 6:08 AM
    TacoRover
    2012 Tacoma TRD
    I appreciate the feedback from everyone and I believe I got my answer and some additional useful information. Thanks everyone!
  11. May 12, 2017 at 6:12 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    4x4 always uses more fuel
    don't drive in 4x4 on dry pavement
    4x4 on wet pavement is ok but sharp turns will cause drivetrain to bind
    4x4 after 50 MPH isn't that safe on pavement
  12. May 12, 2017 at 6:19 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Bad advice, not sure why other people are liking it.
    If you are traveling straight on pavement or even slight turns, why would this damage your truck?
  13. May 12, 2017 at 7:06 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    in a perfect world, no problems
    but there are always slight imperfections in the diameter of front vs rear tires
    if in 4x4 and turning even slightly, or having even 1mm difference in tire diameters, it wears on
    the transfer case harder...wears on everything harder.
    so yes, on paper with perfect mathematical circles for wheels and straight lines, zero issues
    in real life, much more likely to be in a 'greater stress' condition the drier the pavement is,
    and the faster you go, in 4x4
    if you had AWD all these problems go away, but tacoma ain't got AWD, so it is
    always --always-- best to pick 4x4 only when really needed, and leave it in 2wd when 2wd is enough
    TacomaMike37[QUOTED] likes this.
  14. May 12, 2017 at 7:42 AM
    andrew61987
    We don't have enough information to say this. If those 2 hours were driven in snow or on dirt then there's no problem.
  15. May 12, 2017 at 8:13 AM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    4x4 will always consume more fuel; however I haven't noticed it much running in 4x4 this last winter (all winter). I stop worrying about fuel consumption after about 3 months of owning the truck because I was getting shitty gas mileage either way.
    Running in 2hi I'm now averaging about 17-19mpg, I get the 19mpg when I'm constantly aware and go easy on the acceleration. In 4hi, I was consistently getting 17.3-.5mpg.
    If you have a pre-runner you should see better mpg's due to not having the front drive train as a parasitic drag because we don't have manual locking hubs, however I think the difference is too small to be worth much.
  16. May 12, 2017 at 8:15 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    If you really needed 4wd on this trip it is likely that you had more wheel spin and struggled more in 2wd and that is what resulted in your lower 2wd mileage.
  17. May 12, 2017 at 8:30 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    I did once get better mpg in awd on my 4runner on a out-back trip from Boston to NYC
    I did it twice in two days ...and once in awd once in 2wd.
    got 40 more miles on a tank in AWD...so I was like wtf???
    but after examining the situation that was because traffic was balls-thick but f-a-s-t the whole time in CT and I was basically riding
    in the slipstream from everyone else for half the trip, so I got better mpg as I was pushing less air out of the way
    next time I did any awd vs 2wd comparo's they were so close to the same it was meaningless
    summary: all external factors removed....more parts to move more friction = less mpg
