4x4 engagement question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eric J, Jun 9, 2016.
  1. Jun 9, 2016 at 8:53 PM
    Eric J
    Eric J [OP] Well-Known Member
    Ponte Vedra Beach
    2008 MGM dcsb 4x4 Trd sport debadged
    To many to name
    I have a Question about 4wd engagement. I use the 4 high at least 3 times a month if not more. I bought the truck in December and I only engaged low at the dealership to make sure it worked and it did should I engage low ever once in a while or not? Thanks - Eric
    The hammer and BCOutdoorman like this.
  2. Jun 9, 2016 at 8:57 PM
    BCOutdoorman
    BCOutdoorman British Coulumbia Land Lover
    British Columbia
    2016 Tacoma TRD Sport
    This is my first 4x4 and would be interested in the answer to this as well.
    The hammer and Eric J[OP] like this.
  3. Jun 9, 2016 at 8:59 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    10 miles once a month to excercise the actuator. 4l for a few feet is a good idea too.
    BCOutdoorman likes this.
  4. Jun 9, 2016 at 9:00 PM
    Eric J
    Ponte Vedra Beach
    To many to name
    So I need to engage low to?
  5. Jun 9, 2016 at 9:01 PM
    T-Rex266
    Elon
    I would (and do..but keep forgetting as of late :anonymous:) For a few seconds or so.
  6. Jun 9, 2016 at 9:03 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    It is not necassary to engage the 4lo but the 4hi should be done regularly to "excersice the transfer case/solenoids"
    4lo every now and again wont hurt it...
  7. Jun 9, 2016 at 9:04 PM
    Eric J
    Ponte Vedra Beach
    To many to name
    Haven't done it in 6 months do you think it still works?
  8. Jun 9, 2016 at 9:04 PM
    Eric J
    Ponte Vedra Beach
    To many to name
    I use high daily
    The hammer likes this.
  9. Jun 9, 2016 at 9:04 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Doesn't hurt to kick on the locker either if you have one.
    The hammer and T-Rex266 like this.
  10. Jun 9, 2016 at 9:05 PM
    Eric J
    Ponte Vedra Beach
    To many to name
    Don't have one
  11. Jun 9, 2016 at 9:05 PM
    Ice Horse
    Lauren
    Florida
    Saw you had a Sport so knew you didn't (unless you added one of course :D) but figured I'd add that in for anyone who has one! :)
    DustStorm4x4 and T-Rex266 like this.
  12. Jun 9, 2016 at 9:06 PM
    Eric J
    Ponte Vedra Beach
    To many to name
    I wish I did but I don't do any stuff to need one
    Ice Horse[QUOTED] likes this.
  13. Jun 9, 2016 at 9:08 PM
    Eric J
    Ponte Vedra Beach
    To many to name
    I actually called my local shop about a locker they said its 2000$ installed
  14. Jun 9, 2016 at 9:10 PM
    Broccoli
    Airdrie Alberta
    Yes it will still work, if you look in the manual its just advised to do it so things get lubricated and wear into the normal tolerance ranges.
    Take a belt as an example, as its used/worn its tolerances change, it might stretch etc but you have a tensioner pulley to automatically adjust. Your transfer case does not have this function, its a chain that needs to be lubed and kept up like anything else.
    0210 and PROseur like this.
  15. Jun 9, 2016 at 9:10 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I would, every now and then.
    arkywally likes this.
  16. Jun 9, 2016 at 9:10 PM
    Eric J
    Ponte Vedra Beach
    To many to name
    So high is keeping it lubricated?
  17. Jun 9, 2016 at 9:16 PM
    Broccoli
    Airdrie Alberta
  18. Jun 9, 2016 at 9:32 PM
    splitbolt
    NW Arkansas
    It has a trochoid pump operating off a gear constantly.
  19. Jun 9, 2016 at 9:54 PM
    Hellapeno
    Hellapeno Well-Known Member
    Austin
    2016 TRDOR
    Choice Goodies
    Good stuff. Thanks.
  20. Jun 10, 2016 at 5:22 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Yes, I would recommend you engage Lo. Condensation will eventually cause surface rust on the internal components and cause them to bind or pit the gears on the transfer case. Think of the transfer case as a mini transmission or separate from high. It needs to "exercise" and breathe.
    I have seen this binding and surface rust/pitting on seldom used off-road vehicles we acquired from Army surplus for special duty in our fleet.
    These vehicles hadn’t been used in 4X4 in ages and consequently we had to rebuild the transfer cases.
    I myself do engage it (Lo) whenever I’m off road, but I freely admit I may not be putting a full 10 miles a month in Lo, too slow for me lol!
    But this is necessary in order to lubricate/coat all internal transfer case components and to develop heat high enough to burn off all condensation and acid contaminants that forms with temp changes.
    This is even more significant if you live in high humidity areas such as the Gulf coast as I do.
    If not used enough, I’d recommend you change the transfer case and front differential fluids once a year. This is what I will be doing on mine.
    Hope that helps, stay safe.
    Cheers!
