4x4 engagement question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eric J, Jun 9, 2016.
  1. Jun 10, 2016 at 9:46 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    BYE
  2. Jun 11, 2016 at 4:59 AM
    lawrenccar1
    lawrenccar1 Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
    This in my owners manual:
    ■Four-wheel drive usage frequency
    You should drive in four-wheel drive for at least 10 miles (16 km) each
    month.
    This will assure that the front-drive components are lubricated
  3. Jun 11, 2016 at 5:46 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Nope, members here are giving correct info, not 'wrong' info.
    Infrequently used bearings, gears and actuators should be exercised every so often...... not just for a vehicle, but anything mechanical.
    I do this to my transmission.... exercised every gear once in a while.
  4. Jun 11, 2016 at 6:00 AM
    McKerv
    McKerv Member
    Portsmouth, NH
    2015 Tacoma Sr5 4WD
    Luckily in New England it's snowing 8 months out of the year, but during the other months its very easy to find some mud/gravel/grass.
    Not sure what the debate is about this information, it seems obvious that unused parts (i.e. the 4wd components) need to be used to stay healthy. Ever park your car/truck for 2 weeks and when you go to move you feel the rust on the rotors and the wheels break free?
    I guess it depends where you live, but there's always a lawn to drive through...
  5. Jun 11, 2016 at 6:02 AM
    Pigpen
    Dan
    Northwest Montana
    If it was unsafe to activate 4 hi/ 4 lo on hi traction surfaces, nobody would drive in Moab.
  6. Jun 11, 2016 at 9:40 AM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    Use it for what it's made for. Hit a trail once a month or buy a pre-runner.
