4x4 fail?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taco06, Jun 21, 2009.
  1. Jun 21, 2009 at 5:06 PM
    taco06
    taco06 [OP] Well-Known Member
    Alex
    pomona ,California
    06 sprt
    I can't let the wife know
    Hey guys,1st thread.I had my truck for about 6months. Its an 06 extended cab v6 manual 4x4. Took it today off roading for the first time.When I would put in on 4low it would make a griding noise. Not every time but it did it a couple of times then 4L would kick in. Some times the dash would beep to let me know its on 4low but at times when it was on 4low it wouldnt beep.Is this normal?Before i put it into 4h or 4l i would make sure im in a complete stop and clutch in.Is this right?
  2. Jun 21, 2009 at 5:09 PM
    Brunes
    Brunes abides.
    Rotorhead
    If it was beeping you were not in 4Lo. If the light comes on and stays on you are engaged...Other wise it still is in 4Hi
    It sounds like you have the engaging technique down from what I remember...
  3. Jun 21, 2009 at 5:17 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    don't know on the manuals but i know that you need to put it in neutral on the autos. Just confirming what Brunes said if it's blinking and you hear beeping it's not engaged.
  4. Jun 21, 2009 at 5:18 PM
    taco06
    Alex
    pomona ,California
    06 sprt
    there would be times it would beep and it felt in 4l.hmmm Now I wont be able to sleep:confused: What would be a reason if I have it on 4l but it didnt engage?
  5. Jun 21, 2009 at 5:18 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    i hate the 4lo in my truck, ive used it twice, and both times it takes forever to get it out of 4lo. i was driving mtn. roads after climbing a hill and tried to take it out of 4lo and all it would do is beep at me, meaning its still in 4lo.
    i was worried since i was about 30 miles from my house and in 6th gear i can only do about 40, eventually after trying to do rolling to get it out, high reving, reversing you name it i did it. i eventually unplugged the harness on the transfer case, turned off my truck then plugged everything back in. turned my truck on and then went from 4lo to 4hi and it finally popped out.
    pisses me off haha
  6. Jun 21, 2009 at 5:20 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Not to sound like a dick, but this is very thoroughly covered in the owners manual.
    With manual transmission, you have to make sure the truck is at a dead stop and the clutch is all the way to the floor, or else it will beep meaning it has not engaged into 4WL. It is the same when putting it into 4WL and taking it out
  7. Jun 21, 2009 at 5:23 PM
    snowgod06
    Rob
    06 Access Cab
    yea, i read the book when i was trying to get it out, and i did everything it said, with no luck. thats why no matter what now, im staying out of 4lo, 4hi works jsut fine with no problems, but screw 4lo haha
  8. Jun 21, 2009 at 5:25 PM
    DanGer
    Just make sure you push the clutch all the way to the floor, have the shifter in neutral and the truck is at a dead stop.
    I had the same problem and it took me a few minutes to realize that since the clutch engages so far out, I never push the pedal all the way down. I would leave about half an inch of travel on the clutch pedal even when I thought it was fully depressed lol
  9. Jun 21, 2009 at 7:00 PM
    mpgnc64
    mpgnc64 Well-Known Member
    Mike and Denise
    Western NC
    06 4x4 Access cab 4cyl 5spd, 2000 Prerunner
    Tool box, Thule rack, rod holders, 5100s at 1.75 and the TSB
    I had the same problem but the more I used it the easier it got to get out of 4lo. When it beeps I just turn the truck off for about 30sec then start it and its fine.
  10. Jun 21, 2009 at 8:09 PM
    dwalden2
    dwalden2 Your mom goes to college
    Derick
    Blue Ridge, Georgia
    '05 TRD Offroad V6 6 spd
    SCS Stealth 6 Wheels, BFG KM2 tires, Demello Offroad front bumper, 20" LED Bar, LED Fogs, LED interior lights, Wet Okole Seat Covers, Body Armour Rear Bumper, Smittybilt 10K winch, 3" OME Lift
    I had the same problem at first. I was used to the shifter and locking hubs because my last truck was a '94 Toyota. When I got my '05 I had trouble putting it in 4LO but on the visor there's a piece of paper. I read over it and it goes right into 4LO no problem.
  11. Jun 21, 2009 at 8:35 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    I have had mine in the shop because engaging and disengaging 4Lo was and is is a joke
    When I took it in the Service writer couldn't get it to work either and then all of a sudden the service manager comes along and claims we weren't pressing in the clutch far enough an even printed off a page from the owners manual.
    I laughed and opened the door for him and said "show me"
    He gave up after the 11th twist of the knob and me telling him push harder the floorboards are still above the frame dude every time it started beeping
    They had a guy work on it for a bit and claim it is is fine now but it still takes many times and several prayers for the piece of shit system to work
  12. Jun 21, 2009 at 8:44 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    exactly why I dont want electronic 4x4..bad enough I dont have to lock my hubs:rolleyes:
    Thats the one thing i miss about my old 4runner..locked the hubs in october, didnt unlock them untill march-ish..never had a problem:D
