4x4 feels like diff locked
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kaban, Dec 24, 2013.
  1. Dec 24, 2013 at 9:10 AM
    kaban
    kaban [OP] Member
    Kris
    Etobicoke, On
    TRD debadged
    When I'm taking narrower turn with 4x4 on it seems like the front wheels don't spin separately. Especially, while maneuvering with low speed, or even when I roll -up on neutral gear. I had VW before and no such a thing was happening. Mechanics at dealerships say it's the way it supposed to be. Is it?
    Merry X-mass and happy New Year!
  2. Dec 24, 2013 at 9:14 AM
    Iowa 73
    Iowa 73 FNM
    Midwest
    If you are turning and there is good traction available, this is how it will feel. You should only use 4x4 when you need it.
  3. Dec 24, 2013 at 9:16 AM
    smd3
    smd3 Well-Known Member
    It driveline bind, cause by the fact that the transfer case locks the front and rear together. When in 4x4, I would suggest limiting those tight turns, especially in high traction situations.
    When you're making a tight turn all the wheels need to turn at different speeds, not just left and right, but front and back too.
  4. Dec 24, 2013 at 9:20 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    mechanics are correct. Do not use 4x4 in non-slippery conditions, while turning.
  5. Dec 24, 2013 at 9:38 AM
    kaban
    kaban [OP] Member
    Kris
    Etobicoke, On
    TRD debadged
    Hence my concern.
    Thank you all!
  6. Dec 24, 2013 at 9:40 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Normal. And not good, if it's binding up, you're turning on a surface with too much traction for 4ed
  7. Dec 24, 2013 at 12:29 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Never use 4X4 in tight turns....let alone on dry (high traction surfaces). You are experiencing driveline bind.
    This can put extreme pressure on the front CV joints at each wheel (among other things).
    If you ever feel this 'bind' again - DO NOT FORCE IT. Take it out of 4WD.
    Your VW did not have the same 4WD system as the tacoma has. It probably had AWD which is a completely different engineered system.
  8. Dec 25, 2013 at 5:34 AM
    kaban
    kaban [OP] Member
    Kris
    Etobicoke, On
    TRD debadged
    Well, I know I sound like ignorant, which I am, but c'mon, I can tell difference between 4WD and AWD. My VW Caddy had 4WD with haldex clutch, and AWD was Legacy that died last year @ 380000km, used & abused in every possible way. ;) I loved it. R.I.P
  9. Dec 25, 2013 at 6:34 AM
    twillyspree
    twillyspree Member
    Twilly
    South Central PA
    06' Tacoma 4WD
    Don't worry, you're not "imagining" things. I grew up with 4WD and AWD and throw in a CDL (Commercial Driver's License) back when trucking was an honored profession (no offense UPS Guys, you're still the best!) and the Tacoma is the quirkiest truck yet.
    When I first got my 06' Tacoma I was in mud & gravel and it gave that "warning "shudder" that it would prefer to have the 4WD be disengaged. So I disengage it and.... YOU GUESSED IT! - the backs start giving way! At that point I'm just staring at the selector - and asking it to "pick it's poison" Other trucks have not been that sensitive. I've always wondered if the weight distribution is the culprit.
    Sorry about your Subaru, I have a WRX and it absolutely the best handling vehicle I have ever had in any road condition! I have a trip coming up that involves snow & ice and I would much rather take the Subaru but unfortunately, I have to take the Tacoma because of ground clearance issues in back-country.
  10. Dec 25, 2013 at 7:25 AM
    kaban
    kaban [OP] Member
    Kris
    Etobicoke, On
    TRD debadged
    @twillyspree: WRX - beautiful machine, always super glued to the road. Apparently, I am Subaru kind of guy and if they came up with p-u truck - 99,9% I 'd be trading very same second. My every vehicle was manual transmission, I like my machines do what I want. I must say, I'm disappointed with Toyota service, but that's the stories for another thread and long evening :D
  11. Dec 25, 2013 at 8:11 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Subaru cars and Toyota trucks were designed for different purposes. Each one can do things that the other one can't. If you buy an apple but you want it to taste like an orange, you will always be disappointed. But at least your Tacoma has a high resale value if you decide you would rather have a Subaru:)
  12. Dec 25, 2013 at 9:02 AM
    twillyspree
    twillyspree Member
    Twilly
    South Central PA
    06' Tacoma 4WD
    There you go!! Yep - just more ground clearance and I wouldn't have a truck, I'd have that.
    I always wondered about getting a Baja or Brat....
    Didn't the Brat have those rear-facing seats in the bed that were illegal in some states?
  13. Dec 25, 2013 at 2:48 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    If there was a factory Baja STi, I'd consider it as a commuter.
  14. Dec 25, 2013 at 8:02 PM
    DJB1
    Dave
    SLC, UT
    I think there is an aftermarket company that makes spacer lifts for Subarus. They look kinda cool, just not as cool as a 4x4 Tacoma.
