4x4 flange yoke? PTI 1302-37
Discussion in '1st Gen. Tacomas (1995-2004)' started by metaquanta, Dec 22, 2019.
  1. Dec 22, 2019 at 2:46 PM
    metaquanta
    metaquanta [OP] Well-Known Member
    2000 2.7L MT 4x4, 240k mi
  2. Dec 23, 2019 at 1:02 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Might help to know just which one you need .
    What your working on
    If you have a local drive line shop ask them .
  3. Dec 23, 2019 at 7:22 AM
    metaquanta
    I need the flange yoke at the transfer case for a 2000 2.7 4wd. I pulled out the old u-joint because it was pretty stiff and discovered the yoke itself is slightly bent and has hair-line cracks. A brand new u-joint stiffened up as I pressed it in, presumably because of the bend.
