4x4 flash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoman589, Dec 2, 2019.
  1. Dec 2, 2019 at 1:43 PM
    Tacoman589
    Tacoman589 [OP] Well-Known Member
    2020 Army Green TRD PRO
    I used my 4hi the other night to go up a hill in the snow. Switched to N and hit 4H, light came on steady and up I went. Today, I was in N switching from 2WD to 4H. If I stayed in N it just continued to flash. If I waited a few seconds and then went from N to D, the 4x4 went solid. There wasn’t any inclement weather so I did not know if the 4x4 was actually engaged. Same thing with turning it down from 4H to 2WD. Owners manual makes it sound like its okay, but its making me uneasy to think that it will just always blink. It was the first time I used the 4x4, I’ve had the truck a month.
    And yes, I am new to truck gang and 4x4ing (last car was AWD). Just looking for reassurance that the blinking is okay, or if there is something obvious I am missing. Or any help lol. Thanks
  2. Dec 2, 2019 at 1:45 PM
    Myles G
    Myles G Well-Known Member
    Myles
    4x4 has always been funky on my tacomas 2nd gens, 3 gens, autos, 6 speeds. Its wonky youll feel it engage/disengage.
    Tacoman589[OP] likes this.
  3. Dec 2, 2019 at 1:46 PM
    heybronicetacoma
    heybronicetacoma Meat Popsicle
    Claro
    Seattle
    ‘20 DCSB MT OR SSM
    Mods? Yes.
    You can go in and out of 2hi / 4hi without stopping under 60mph. The engagement may take a second and once it is solid green, you are good to go. You should be moving tho, and I recommend not doing it under load or while spinning.
    Chew, Taco_Craig, tonered and 2 others like this.
  4. Dec 2, 2019 at 1:47 PM
    Tacoman589
    Yeah I came to a stop before I switched. Do you think the blinking light is a concern? All videos (and the first time I used it) make it seem like it should go solid pretty quick.
  5. Dec 2, 2019 at 1:47 PM
    Myles G
    Myles
    and like stated above it is very difficult to engage 4low/high once you are stuck so make sure you are engaged before anything rough or sugar sand
  6. Dec 2, 2019 at 1:50 PM
    heybronicetacoma
    Claro
    Seattle
    ‘20 DCSB MT OR SSM
    Mods? Yes.
    Not a concern at all. Sometimes mine takes longer to engage/disengage (blinking) than others. It really has to do with the alignment of the system. Always roll while doing it.
    Some helpful info:
    https://www.tacomahq.com/4546/toyota-tacoma-4-wheel-drive-explained/
  7. Dec 2, 2019 at 1:50 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The blinking light is the system telling you that it is in transition and not fully locked in yet. Sometimes, turning a bit or wiggling the steering for 4Lo will get it done. Once it is solidly lit, you are fully it.
  8. Dec 2, 2019 at 1:51 PM
    Tacoman589
    so always be moving forward when switching 2 and 4H? I know 4L has to go to park then N. Sorry for the dumb questions but I appreciate the patience and feedback. Will definitely check that link.
  9. Dec 2, 2019 at 1:52 PM
    heybronicetacoma
    Claro
    Seattle
    ‘20 DCSB MT OR SSM
    Mods? Yes.
    I should add that for switching form 4hi to 4lo and vice versa, you MUST be in neutral and (for AT) absolutely wait for everything to be done before going back to D. If it beeps, just switch back to 4hi, roll a little, try again.
    Yep! But 4L does not need P then N, just D to N :)
  10. Dec 2, 2019 at 1:52 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    This is very true, but . . .
    This is somewhat not true. Driving straight on dry pavement is just fine. Turns and corners will start to bind things though.
  11. Dec 2, 2019 at 1:53 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep. You got it.
  12. Dec 2, 2019 at 1:54 PM
    heybronicetacoma
    Claro
    Seattle
    ‘20 DCSB MT OR SSM
    Mods? Yes.
    100%. "Not driving on pavement" is about differentials binding (namely the front LSD) when turning.
    Edit: in case folks come here later, please note the correction by @tonered below:
    GreyBaldTaco and tonered[QUOTED] like this.
  13. Dec 2, 2019 at 2:03 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
    I hear you. But, folks gotta learn at some point.
    Besides that, I think we all took a corner while accidentally in 4Hi once or twice. Hahaha!
  14. Dec 2, 2019 at 2:05 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :cheers:
    Just saying, but we don't have LSDs. The binding is caused by the T case and the front and rear axles following two different arcs through a corner.
    No big deal though. Just that part time 4wd is very different than AWD.
    420taco likes this.
  15. Dec 2, 2019 at 2:08 PM
    rjbt770
    rjbt770 Member
    ronnie
    bay area, Ca
    2006 DCSB 4x4 off road
    Has anyone hitt the diff lock switch instead of the fog light switch lol i have
  16. Dec 2, 2019 at 2:13 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  17. Dec 2, 2019 at 2:25 PM
    Tacoman589
    So another dumb one...switch back to 2wd before making a turn?
    tonered[QUOTED] likes this.
  18. Dec 2, 2019 at 2:34 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    No. If the conditions support 4wd stay in 4wd. Just dont be doing any full lock slow speed turns while 4wd is engaged and the roads are dry.
  19. Dec 2, 2019 at 3:57 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep! If on pavement. If on dirt, you don't have to.
  20. Dec 2, 2019 at 4:07 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    My thought is better to be in 4hi and not need it vs the alternative.
    Tacoman589[OP] and tonered like this.
