4X4 Guide or Sticky?
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, Oct 31, 2011.
  1. Oct 31, 2011 at 11:12 PM
    prerunnerSD
    prerunnerSD [OP] "I Brake for Tailgaters"
    Northeast USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    Is there a guide or sticky or good post that explains best practices to operate 4x4 on a 1st gen tacoma.. i just dont wanna mess anything up
  2. Oct 31, 2011 at 11:32 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    put it in neutral or park. Or disengage the clutch. Pull down the lever to 4wd..drive and have fun.
  3. Nov 1, 2011 at 2:35 AM
    prerunnerSD
    Northeast USA
    i dont have the owners manual
  4. Nov 1, 2011 at 2:35 AM
    prerunnerSD
    Northeast USA
    what about 4x4 lo or hi? same difference.. thought u can only go 5mph for hi
  5. Nov 1, 2011 at 2:44 AM
    prerunnerSD
    Northeast USA
  6. Nov 1, 2011 at 7:07 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    nah manual says like 55mhp for 4wd hi and i have been as high as 4th gear in lo so like 20ish i think
  7. Nov 1, 2011 at 9:13 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    since this thread is here, whats the max speed in 4LO? Like blawkdawg said i have also been in 4th gear in 4lo...just wondering if that would cause any damage? Wish I had an owners manual for my 97.
    The manual posted above also says that 4HI can be used on wet roads...I thought 4wd on the road was a huge no-no unless there is snow/ice?
  8. Nov 1, 2011 at 3:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea i use my 4wd in winter for snow and ice a lot. No issues here.
    And i think 25mph is as fast as the Tcase will let 4lo go..don't quote me on that tho.
    In all honesty tho, if i feel like i want to go faster, i just stop and put her back in 4hi. if want to go 20mph for a long period of time. If its only for a short burst, i doubt you'll hurt anything.
  9. Nov 1, 2011 at 4:02 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    If the road is wet enough to allows tires to slip, so there isn't binding or difficulty turning, the 4WD on wet roads works... but use it only if you need the extra traction (or to keep the parts lubed for a few miles).
    Low Range is a lower gear ratio for crawling with max. power/ min. speed... unless you like to red line your engine, there is a limit to how fast you can go in low range. Use it for steep, bad grades and crossing deep mud or deep snow where extra torque/ power is helpful.
  10. Nov 1, 2011 at 4:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea i usually keep it under 20 for lo and 50 for hi.
