4x4 Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Meteorasc32, Dec 23, 2010.
  1. Dec 23, 2010 at 11:50 AM
    Meteorasc32
    Meteorasc32 [OP] Member
    Shane
    Albuquerque, NM
    08 Off Road DC
    When I tried switching my Tacoma from 2Lo to 4Hi. I have the warranty but with family being in town I don't have time to take it to the dealership. Any ideas as to why its doing that? Also, the 4wd light keeps blinking and when I switch it back to 2 Hi it continues to blink.
  2. Dec 23, 2010 at 11:51 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    You left a key part out, what is it doing?
  3. Dec 23, 2010 at 11:52 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Is it just the blinking?
  4. Dec 23, 2010 at 11:52 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    First, you don't have 2Lo. Second, put it in neutral and try on flat ground to see if 4hi will engage.
  5. Dec 23, 2010 at 11:52 AM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Read the little card thingy on your visor, it'll tell you the correct steps to put it in to 4wd.
  6. Dec 23, 2010 at 11:55 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    So what's the problem now?? Be specific it helps!
  7. Dec 23, 2010 at 12:16 PM
    Meteorasc32
    Shane
    Albuquerque, NM
    08 Off Road DC
    That is all that is happening. Usually you hear the click of the 4wd engaging but all it does is blink. I've read the card and the manual and I have tried every way I could think of, at a stop with the truck in neutral, accelerating, decelerating, maintaining speed etc. When I move the switch over the only thing that happens is the light blinks.
  8. Dec 23, 2010 at 12:28 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    turn your engine off but keep the key on so all the electronics work. then flip the swtich from 2 to 4 and back to 2. do you hear a tiny motor or any clicks at all? the actuator may not even be moving
  9. Dec 23, 2010 at 12:42 PM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    If you have tried and followed all the instructions per the card & manual it might be your actuator.
    Mine went @ 16k no warning same conditions you describe.
    Dealer fixed under warranty.
    It just blinked not stop.
    I was able once, just once to get to go into 4LO then that was it. Replaced part, truck now has 52k no issues.
    Good luck
  10. Dec 23, 2010 at 12:43 PM
    numbah57
    kahai
    Maui, Hawaii
    How long since you last used your 4wd?
  11. Dec 23, 2010 at 12:49 PM
    Meteorasc32
    Shane
    Albuquerque, NM
    08 Off Road DC
    I use it at least 2 times a week.
  12. Dec 23, 2010 at 12:55 PM
    Meteorasc32
    Shane
    Albuquerque, NM
    08 Off Road DC
    I tried just turning the key to the on position and I didn't hear anything.
  13. Dec 23, 2010 at 1:05 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Sounds like your actuator is failing. The only thing I can think of it to back up a little, engage your switch to 4 Hi and go forward.
