4x4 help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by black cx, Dec 7, 2009.
  1. Dec 7, 2009 at 6:55 PM
    black cx
    black cx [OP] Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
    I was stuck in a snow storm this weekend..
    Whats the difference between H4 and L4?
    I had no problem getting into H4...but when i tried L4...it kept beeping...
  2. Dec 7, 2009 at 7:08 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    L4 is low range 4x4 you need to be in neutral stopped if you are in an auto or you need to push the clutch through the floorboard if you have standard before you switch to 4L.
    it is generally used for off roading the final drive ratio is alot higher so the truck will go alot slower
  3. Dec 7, 2009 at 7:14 PM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    so i dont need to use L4 unless im going offroading?
    i have a 6spd..
    i know how to get into H4 (engage clutch in neutral at a stop)
    how do i get into L4 tho? (It just kept beeping...
  4. Dec 7, 2009 at 7:23 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    4hi is fine in the snow, only use 4lo if you slide off into a ditch to get out
  5. Dec 7, 2009 at 7:25 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    like i said push the clutch through the floorboards and you can engage 4h on the fly just make sure you are under 60mph
  6. Dec 7, 2009 at 7:29 PM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    im talking about 4L
  7. Dec 7, 2009 at 7:32 PM
    z33tec
    z33tec Well-Known Member
    Rochester, NY
    09 4X4 Access Cab 4cyl
    You can engage 4Hi without pushing the clutch in.
    There's a little plastic card in your truck that should be in your visor that will explain how to use 4Hi and 4Lo.
  8. Dec 7, 2009 at 7:44 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    so was i no prob :thumbsup:
  9. Dec 7, 2009 at 7:45 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    yeah i didnt mean push it when you're driving wording was off i suppose
  10. Dec 7, 2009 at 8:11 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    You need to be in 4hi first which you can do while traveling down the road like already mentioned. Then you need to stop and get into neutral or press in the clutch then push the button in and rotate to 4lo. Then, roll slowly forward or back ward until the beep stops and the light goes from flashing to solid. On streets with snow you really don't need 4lo, unless maybe you want to crawl up or down a steep hill. Your max speed in 4lo is only around 5 or 10 mph...depending on what gear your in. The main thing to remember with 4wd is to never be engaged on dry pavement...and if the snow on the road goes from covered to bare and your in 4wd make sure you don't turn on the bare spots...you need slippage while in 4wd especially while making turns.
  11. Dec 7, 2009 at 9:08 PM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
