4x4 high not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by captaingeech08, Aug 10, 2010.
  1. Aug 10, 2010 at 10:39 AM
    captaingeech08
    captaingeech08 [OP] Active Member
    Dan
    Bend OR
    ‘18 TRD OR DCSB
    Icon Coilovers, Duratracs, Deaver Springs, Pop N' Lock, Pro Grill, LEDs Everywhere
    Nothing happens when I shift into 4x4 high, but when I put it in 4 low the light comes on and it works fine. Do I need a new transfer case?
  2. Aug 10, 2010 at 10:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    How do you know high isn't working?
  3. Aug 10, 2010 at 10:42 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Get on a gravel road, put it in 4x4 high and try doing a burnout. If at least one of the front tires burns out, its working haha.
  4. Aug 10, 2010 at 10:46 AM
    captaingeech08
    Dan
    Bend OR
    ‘18 TRD OR DCSB
    I have done the burnout test and my front wheels do nothing unless I shift into 4 low.
  5. Aug 10, 2010 at 10:54 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    will it go in to 4hi after shifting to 4lo first there might be something misaligned in the actuator :notsure:
  6. Aug 10, 2010 at 10:56 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    yeah, or maybe you have a wiring problem where the hubs are not locking when the shifter is in 4 high. The problem is most likely the hubs and not the transfer case.
  7. Aug 10, 2010 at 11:01 AM
    98tacoma27
    Ben
    Not Beech Creek
    The hubs don't actually lock. It's the axle that connects to the diff. If it is engaged in 4lo, it's engaged in 4hi. It has to be a transfer case issue.
  8. Aug 10, 2010 at 12:59 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I did not know that. I always thought the hubs were locked by a switch when you put the lever in 4x4.
  9. Aug 10, 2010 at 3:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    On ADD, the axles are turning all the time. That's part of the reason for switching to manual locking hub if you are going to tow the truck behind an RV a lot or if you put an automatic locker in the front diff.
    I can't see how there could be anything wrong with the Tcase itself if it works in 4lo. The problem must be electrical. What is it that actually occurs when I click the 4WD button on the Tcase lever? All that moving the Tcase lever manually does is engage the low range gears inside the Tcase doesnt it? 4WD is already engaged.
  10. Aug 10, 2010 at 4:17 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Its probably the switch for 4hi. There should be two switches, one that tells system when you in 4hi one that tells system when you are in 4 l. I bet the switch for 4hi is busted.
    EDIT: I am assuming you have ADD right. And I am talking about switches (aka shift position sensor) inside the transfer case.
  11. Aug 10, 2010 at 6:01 PM
    98tacoma27
    Ben
    Not Beech Creek
    Are you auto or manual? OP is manual
  12. Aug 10, 2010 at 6:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ah, so no button. Is the case itself different between autos and manuals?
  13. Aug 10, 2010 at 6:14 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, you also have a V6 which has an A340F where the OPs will have a W59 tranny
  14. Aug 10, 2010 at 6:20 PM
    98tacoma27
    Ben
    Not Beech Creek
    Here is the difference between the Transfer cases. According to this, the V6 was the only one available wit the "One touch" system.
  15. Aug 10, 2010 at 6:59 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks for the drawings. Those were very enlightening.
    Looks like mine has some sort of actuator whereas the OPs has a shift fork/shaft assembly with a spring. I withdraw my comment that it has to be electrical. In fact, from looking at the drawings it looks like something is going on with his front drive fork/spring/shaft assembly.
