4X4 High
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wenkev, Jan 26, 2014.
  1. Jan 26, 2014 at 3:04 PM
    wenkev
    wenkev [OP] Well-Known Member
    Kevin
    Louisiana
    2010 Double Cab TRD Off Road
    Stock
    I am new to having a 4WD. I heard it is good to run the 4wd regularly for good maintenance. When I run the 4WD high and I am driving slow like parking or turning around, it seems difficult for it to move and I have to accelerate more for it to move. When it does move, it is not smooth. Is this normal? What say you experts?
  2. Jan 26, 2014 at 3:06 PM
    Large
    Large Red
    It's good to use 4wd once a month, but you should do it when there is very low traction like sand or gravel, not pavement. Your transfer case is binding.
  3. Jan 26, 2014 at 3:07 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Only us 4x4 if the tires can slip, like off road on sand, rocks, or on snow and ice.
  4. Jan 26, 2014 at 3:12 PM
    woof359
    woof359 Well-Known Member
    I tell all my customers to use there 4WD at least month a month, summer and winter, it keeps things lubed up, the front ADD system can get a little sticky in cold weather
  5. Jan 26, 2014 at 3:15 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    You can use it on pavement, but make sure you're going in a straight line. Turning, especially tight turns, will bind the driveline and could break something. That's what you're feeling when it's difficult to move.
  6. Jan 26, 2014 at 3:15 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    First never run 4x4 on pavement. Go find some dirt or a good logging road and engage 4x4 there.
  7. Jan 26, 2014 at 3:17 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Its fine on pavement if you don't turn. Why does everyone say this?
  8. Jan 26, 2014 at 3:19 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Never engage your 4WD on dry pavenment... read the links below for more information.
  9. Jan 26, 2014 at 3:25 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    The manual says to drive 10 miles a month in 4wd to keep the hubs lubricated. Don't do it on dry pavement, though. In 4wd the front and rear differentials are locked together and can't turn at different speeds. If you're in 4wd on dry pavement and you're turning, the front and rear differentials want to turn at different speeds but can't, so you will feel the drivetrain binding. FYI, turning in 4wd on dry pavement is about the worst thing you can do to your 4wd components. On dirt, snow, mud, etc, in 4wd (AKA the places you're supposed to use 4wd), you usually won't feel binding because the tires will skid easily on the slippery surface. Some people won't use 4wd on wet pavement when it's raining. I think it's OK as long as you don't make sharp turns or park in 4wd. Hope this info helps!
  10. Jan 26, 2014 at 3:28 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    And if you're going straight they're all spinning at the same rate, so its fine as long as you don't turn.
  11. Jan 26, 2014 at 3:49 PM
    DJB1
    Dave
    SLC, UT
    Probably because NOT using 4wd on dry pavement where it is not needed requires zero effort.
  12. Jan 26, 2014 at 3:52 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    True.
  13. Jan 26, 2014 at 4:22 PM
    OffroadToy
    In what circumstance would you even concider engaging 4WD on dry pavement? Are the pot holes that bad where you live? :confused:
  14. Jan 26, 2014 at 4:26 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    No but around here it's near impossible to find dirt roads. If you feel the need to engage 4wd every so often and have no dirt to do so it's fine to drive a a mile on pavement in 4wd if you don't turn.
  15. Jan 26, 2014 at 4:36 PM
    Tacoma Mike
    Southern Maine
    Hehehe here we go again.
    I engage mine once a week, 4 low once a month
    On dry pavement at 40 mph IN A STRAIGHT LINE on my way to work.
    My son does the same.
    There are no issues.
    Let the shit storm begin hehehehehe
  16. Jan 26, 2014 at 4:37 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Same
    Occasionally I even *GASP* turn , just not sharply
  17. Jan 26, 2014 at 4:38 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    X2 you got to work with what you got. In the summer I find a straight away here and there. Best I can do most of the time. This winter though its been getting a good work out.
  18. Jan 26, 2014 at 4:41 PM
    Graham
    Graham Pay it Forward
    Western New York
    2005 4x4 TRD Black V6 6 speed manual
    ^This
  19. Jan 26, 2014 at 4:46 PM
    OffroadToy
  20. Jan 26, 2014 at 4:47 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    Same
    The hand wringing and panic over 4wd on dry pavement is truly comical. How many miles are driven in 4lo w/ lockers engaged every year at Moab.
    David
