4X4 High
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wenkev, Jan 26, 2014.
  1. Jan 31, 2014 at 6:25 AM
    #61
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Not that stupid story again?
    Did you read it?
    First off if you are stupid enough to drive at freeway speeds with it in 4wd then you deserve to have crap like this happen.
    The dumb ass was driving 70 mph:eek:
    Moral of the story if you are a common senseless person then read the story.
  2. Jan 31, 2014 at 10:48 AM
    #62
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The problem is that's exactly what some on this thread (yourself included) are advising other's to do... :rofl:
  3. Jan 31, 2014 at 10:51 AM
    #63
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You can drive at high speed in 4WD , where does Toyota state that you cannot ?
  4. Jan 31, 2014 at 10:53 AM
    #64
    OffroadToy
    I believe they include the word "slippage" though.
  5. Jan 31, 2014 at 10:59 AM
    #65
    OZ-T
    Peter North
    British Columbia
    What ?
  6. Jan 31, 2014 at 12:19 PM
    #66
    OffroadToy
    Yes... of coarse you can drive at highway speeds in 4wd... but it's advised to do so when 4wd is needed (for greater traction than 2wd (like when you experience a loss of power, such as wheel spinning.) 2wd is meant for normal driving on dry hard surfaced roads. No where in the owners manual (at least mine) does it say it's ok to drive in 4wd at ANY speed on dry pavement. Does your manual state othewise? :confused:
    http://www.eulex-kosovo.eu/training/security/docs/Guide.to.4WD.pdf
  7. Jan 31, 2014 at 12:23 PM
    #67
    OZ-T
    Peter North
    British Columbia
    I didn't say anything about road conditions , I was pointing out that there is no caveat against higher speeds in 4WD
  8. Jan 31, 2014 at 12:25 PM
    #68
    OZ-T
    Peter North
    British Columbia
    Nice Kosovo Toyota manual !
  9. Jan 31, 2014 at 12:27 PM
    #69
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I never use 4wd High :rasta:
    ...and I've already shared my opinion of when it's appropriate to use 4HI / 4LO :D
  10. Jan 31, 2014 at 12:51 PM
    #70
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Bottom line is, its your truck. Do whatever you want with it. OP. My advice, if there's binding. Turn off 4WD.
    I use 4WD when I need it, and occasionally in the summer to lube things up. Most of the time when there's no snow, I don't and plain just forget to turn it on for lube purposes. It's my opinion that its not good to drive with it in 4WD on dry pavement, so guess what? I don't. And no one can make me! :D
  11. Feb 1, 2014 at 8:17 AM
    #71
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Please link where I advised someone to drive 70 mph while in 4x4? oh can't find it then shut it.
  12. Feb 1, 2014 at 9:02 AM
    #72
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Me thinks 10 miles a month is excessive. How about a 1/4 mile? Dry pavement going straight no problem, Hi/Lo range no biggie, 2-5 mph ought to stir the lube a bit. Once maybe twice a year.
    Dirt and gravel roads aplenty around my location so maybe a few/1/2 dozen times a summer depending on fishing/camping, mine gets engaged more frequently.
    Would occasionally lock rear diff. for function check too.
    Just my 2 cents worth.
  13. Feb 1, 2014 at 9:14 AM
    #73
    OffroadToy
    Your right YouTard... you said 60 mph not 70... but went on to say "if your stupid enough to drive at freeway speeds with it in 4wd then you deserve to have crap like that happen". I don't know how it is where you live but around here 60-70 mph are freeway speeds. :rolleyes:
  14. Feb 1, 2014 at 9:48 AM
    #74
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Well here in Utah where all the Utards live we have freeway speeds up to 85 mpg:cool:
    And if you look at the photo you will see something that is right in front of your face every time you get in your truck:rolleyes:
  15. Feb 1, 2014 at 10:07 AM
    #75
    cjacob
    cjacob Well-Known Member
    Lafayette, La
    '05 PreRunner SR5 TRD
    I don't know why you would own a 4x4 if you didn't have places nearby to use it. I think "regular maintenance" is a good excuse to take a scenic drive on a dirt road every now and then.
  16. Feb 1, 2014 at 11:22 AM
    #76
    OffroadToy
    Just to let you know... "freeway speeds" in the U.S. range between 60-85 mph. :rolleyes:
  17. Feb 1, 2014 at 12:36 PM
    #77
    OZ-T
    Peter North
    British Columbia
    snow
  18. Feb 1, 2014 at 2:20 PM
    #78
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    tow
  19. Feb 1, 2014 at 2:23 PM
    #79
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Flow
  20. Feb 2, 2014 at 9:57 AM
    #80
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    ACKNOWLEDGE MOVE ON!
    Take it like a man that you lost this round.:cool:
