4x4 How often to engage it?
Discussion in 'General Tacoma Talk' started by Javman, May 27, 2025 at 12:42 PM.
  1. May 27, 2025 at 12:42 PM
    Javman
    Javman [OP] Active Member
    I'm new to 4x4 experience with my 2019 Tacoma SR Access Cab.
    I've read that one should use the 4x4 once a month or every 60 days or so.
    My question is should I be engaging the 4x4 Low as well in addition to 4 High?
    Or, would just engaging the 4 High and driving it in 4 High for a few miles be enough to prevent the locking up or freezing up of gears in the transfer case?
  2. May 27, 2025 at 12:43 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I have a 2009 4x4...I engage it once or twice a month...
    sparkystaco likes this.
  3. May 27, 2025 at 12:50 PM
    Clearwater Bill
    Billy
    Largo Florida
    Does the owners manual have any recommendations?
    If you didn't get one, a free PDF version can be had from the Toyota website.
    Javman[OP] and HondaGM like this.
  4. May 27, 2025 at 1:28 PM
    mict450
    mict450 got heel toe?
    northeastern California
    2017 TRD Sport AC MT BBP
    Rarely, if ever, done, on any of my 4x4's. Still works fine, lasts for years. Just remember to change transfer case & front diff fluids per owner's manual.
  5. May 27, 2025 at 1:39 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I try to engage 4WD every month or two. I wait for a rainy day on a stretch of fairly straight road (gentle turns okay) and engage 4 HI. I haven’t engaged 4LO recently but it wouldn’t hurt to do it in the driveway just to make sure it goes in.
    xBloodxLinex, Sprig and Williston like this.
  6. May 27, 2025 at 1:59 PM
    Williston
    Williston Unknown Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    2014/2nd gen. I engage mine sitting in the driveway 2-3 times per month or whenever I think of it to exercise the actuators, transfer case and linkages: 4H and 4L. When I'm driving, if it's raining and the road is fairly straight, I engage 4H for a mile or two. Non-use is one of the main causes of problems with the 2nd gen system. The contacts in the actuators get balky and oxidized, and the linkages on the front axle get cranky.
    It's asking for trouble if you let the components, and linkages (front axle diff and transfer case) take an extended vacation.
    vssman likes this.
  7. May 27, 2025 at 10:07 PM
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    Manual said to engage 4wd monthly for about a few miles (I think 10 miles-too lazy to check) on slippery surface.
    i use this excuse on wifey to go play in the dirt once every 2-3 months.
    Williston and apreston1 like this.
  8. May 27, 2025 at 11:33 PM
    xBloodxLinex
    xBloodxLinex Active Member
    Gary
    2017 SR5 SCLB Barcelona Red
    Same. I engage 4H going down a straight stretch of road/highway (under 60mph) for a mile or two when it's raining. The Car Care Nut has a good video on this topic. I follow his recommended way of doing it, just simply driving down a straight stretch of road, and flipping it to 4H for a while then going back into 2WD. In his video, it isn't raining and he doesn't state it needs to be, that's probably me just overthinking things and wanting to be extra sure hah.
    Javman[OP] likes this.
  9. May 29, 2025 at 3:41 PM
    Archie boy
    Archie boy Well-Known Member
    Archie
    Santa Cruz
    2020 Tacoma TRD OffRoad 6footie
    Gfc, eibach suspension, Rrw wheels, prinsu roof rack,
    Following this thread
    xBloodxLinex likes this.
  10. May 30, 2025 at 5:11 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    About 10 miles/month used to be recommended. I know from experience that if you fail to use it for months at a time there is a good chance it won't work when needed.
    I don't have a set routine but I'm on a gravel road most months for 3-4 miles. I always engage 4X4 when on that road, but I never go out of my way to do so. Occasionally I may skip a month but don't like to skip 2. Some months I may only get in 3-4 miles, other months (during hunting season) I may get in 300-400 miles in 4X4.
    A word of caution about using 4X4 on pavement, or any surface with good traction. Even on slow gradual curves each wheel needs to turn at different speeds to get to the same place. In 4X4 the transfer case tries to make all 4 turn at the same speed. Something has to give. On a loose surface 1 or 2 wheels will spin slightly on the surface. If traction is too good for this slight slippage it puts internal parts in a strain. They rarely fail that day but do wear out prematurely.
    The more you do this the sooner you'll be replacing U-Joints, CV axles and eventually the chain in the transfer case. Technically in a pretty straight line and wet pavement does help you should be OK. The problem is when you have a brain fart and forget you're in 4X4 and make a sharp turn onto another road or business.
    IME the reward isn't worth the risk. Find a loose dirt or gravel road to do this.
    Williston and Javman[OP] like this.
  11. May 31, 2025 at 8:02 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    2007 bought new. I only engage for offroading and snow/ice... that's it. After 18 years still works flawlessly. I'd never engage 4WD on pavement wet or dry.
    xBloodxLinex and Javman[OP] like this.
