4x4 Illuminated switch and cup holder light mods
Discussion in 'Lighting' started by NetMonkey, Mar 1, 2010.
  1. Mar 1, 2010 at 8:00 PM
    NetMonkey
    NetMonkey [OP] Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    special thanks to rcbs204 for the 4x4 switch light. :)
    i mostly followed his directions:
    http://docs.google.com/fileview?id=...TEtYWMzMS00MWE1LTg5ZmQtN2NlMDkxMWZjNzY4&hl=en
    but i will show where i did it differently.
    i started by removing the 4x4 switch and the AC panel. i used my finger nails to pry the 4x4 switch out and a butter knife to pry the AC panel out.
    put in rcbs204's lighted 4x4 switch board. the hardest part was pulling of the cover because i didnt want to break any of the tabs holding it together.
    all back together
    i was going to use the solder method, but i only had a soldering gun and the tip was way to big for the delicate area on the switch. so i decided that i would wire it directly to the AC lights. but i still wanted to be able to disconnect the switch so i picked up some quick disconnects.
    i cut the wire from the circuit board and crimped on the disconnects.
    then i crimped on the disconnects to the other end of the cut wire.
    disconnects wired in a ready to install.
    it took me a bit, but i was able to find a path through the dash to the AC control opening. this is the view from the 4x4 switch opening.
    pulled the wire through the opening in the AC control area.
    i disconnected the AC wire harness (which was a pain in the ass) and isolated the green wires.
    for lack of better tools, i took the edge of a knife and scraped the wire until it cut through the insulation (there is not much room to work in there). i then used my fingers to separate and expose the wires.
    i hooked up the wires and did a quick test (red->solid green, white->green stripe).
    while i was in there messing with wiring, i also wanted to add some lights to the cup holder area. at night, its really dark and its impossible to see the cup holder (i am always fumbling to get my drink back in). so i added another wire to the AC lights to run it to the cup holder. i am embarrassed by my super, hack-tackular wiring job :rolleyes:
    all taped up
    it took me a few minutes to find and thread a path through the dash to the cup holder. i also addded quick disconnects. BTW, the cup holder prys up easily by using your fingers on the front.
    i pickd up 2 orange LED's from here:
    http://www.oznium.com/prewired-superflux
    i also picked up a package of 3/8" grommets from home depot (8 for $3).
    the stock 2010 cup holders. where the hell do you put LED's in this? pre-2010, there was a plastic divider in the holder and you could easily drill up from the buttom of the holder.
    i decided to drill from the side of the holder and into the rubber cups. i wasnt too sure how bright the LED's would be being recessed into the rubber, but it was worth a try :)
    i tried taking measurements as best i could, but i ended up eye balling some of it.
    grommets in.
    LED's in. they are VERY tight in the grommet. they are not coming out.
    looks pretty clean
    all wired up in the truck
    tah-dah! it actually is perfect for me. looking directly at the LED's will blind you, so having them diffused is less of a distraction. also, from where they are poistioned, they light up the accessory ports and the switches where the A-Trac button is.
    view of the completed 4x4 switch.
    view of everything completed.
    i am pleased with the out-come.
    the 4x4 switch took about 30 minutes, but the LED's took about 2 hours because i had to figure everything out.
    i also have to say that the features on the tacoma kick ass. it was so nice to drop the tailgate and work at the back of the truck. i was able to use my dremmel and drill using the outlet at the back of the truck. :)
    Pacific_roots and tacomatrd22 like this.
  2. Mar 1, 2010 at 8:02 PM
    thebigk
    thebigk 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    SWEET! Nice write up! Gonna tackle this next weekend hopefully!
  3. Mar 1, 2010 at 8:06 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    SEXY!!! I need to do both those mods
  4. Mar 11, 2010 at 7:47 PM
    BigTacoMan
    BigTacoMan Active Member
    JEF
    Houston
    2010 Black TRD Sport,
    BSP Eyelids,BHLM,Tinted Taillights,CupHolder LEDs
    I have my LED's on order and waiting for thier arrival to start this mod. Looks badass
  5. Mar 11, 2010 at 7:58 PM
    TRDguyKC
    TRDguyKC Well-Known Member
    Kris
    Glendale, AZ
    awesome. i just got my 4x4 switch in the mail today.... gonna go home and put it in.
    nice write up btw. im going with your method.... i dont solder lol.
  6. May 21, 2010 at 8:12 AM
    bass11
    bass11 Member
    Bob
    IL
    Looks good, i'm considering doing this but i'm thinking of using one light instead of two. Just curious, how bright is it with the two you mounted in the backside of the holder? I'm looking for some light but definately don't want it to be too bright? Any info would be greatly appreciated, thanks
  7. Oct 11, 2010 at 4:41 PM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Nitto Terra Grappler G2, Suspension: Icon coilovers set at 2.5", TC UCA's, 1.5" lift 3 leaf pack with overload left in, 3* shims, carrier bearing drop, Bilstein 5100 B110 rear shocks Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau Cosmetic: window tint, grillcraft black mesh upper/lower grill, eyelids, tinted tails and third brake light, vinyl armrest in doors and center console Lighting: fogs only mod, bed lights in pockets, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights
    Just wondering if the LED's dim when you dim the dash lights since you tied into the AC for power supply. I don't know, can LED's even be dimmed?
  8. Oct 12, 2010 at 10:12 AM
    lasllc
    lasllc Well-Known Member
    SW Denver Burb
    13 SuperWhite DCSB Sport 4X4 Tow Pack
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    I like this. I like the disconnect idea. Just in time as my switch board is in the mail.
    Sent you a pm also.
  9. Oct 12, 2010 at 10:13 AM
    trd7
    trd7 4wd tacoma
    Tyler
    Columbia, SC
    95.5 Tacoma 4x4 4cyl auto
    AEM air intake
    looks great!!!
  10. Oct 12, 2010 at 10:18 AM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    nice work boss
  11. Oct 12, 2010 at 10:20 AM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Thanks for adding this to the thread, looks like everything lights up nicely.
    Great Job.
  12. Oct 14, 2010 at 10:26 AM
    NetMonkey
    Geogetown, TX
    if you were able to see the LEDs directly, the light would blind you at night. but with them being recessed behind the rubber cup holder, you just get the ambient glow. i am happy with how it turned out,
    ya.. hmm... i hadnt thought about that. actually, i havent even looked to see. i always keep the dash lights on at the max. the next time i drive at night, i will find out for sure :)
  13. Oct 14, 2010 at 10:27 AM
    NetMonkey
    Geogetown, TX
    sure thing :)
  14. Oct 15, 2010 at 5:42 PM
    NetMonkey
    Geogetown, TX
    heh... the LED's do dim with the dash lights :)
  15. Dec 25, 2010 at 12:49 PM
    arrowthrower
    arrowthrower Well-Known Member
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    Just ordered the leds for the cup holder. Are they still doing well for you?
  16. Dec 25, 2010 at 9:58 PM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Anyone know how to illuminate the foglight switch for on/off?
  17. Dec 27, 2010 at 9:57 AM
    NetMonkey
    Geogetown, TX
    yup... still working great :)
  18. Dec 30, 2010 at 7:48 AM
    arrowthrower
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    Installed them last night. It was easy. Great write-up. It went like clock work. I will post some pics later. It makes the whole cab area!!!
  19. Jan 1, 2011 at 7:06 AM
    NetMonkey
    Geogetown, TX
    great!
  20. Apr 6, 2011 at 3:18 PM
    wrecklessfool
    wrecklessfool Well-Known Member
    Monterey, CA
    2016 BBM TRD Sport DCSB 4x4
    Very nice work! I just finished installing the 4X4 light kit I picked up from RCBS. I used the solder method and it turned out great. I'll definitely be doing the lighted cupholders like you did. Thanks for the idea and the inspiration.
