4x4 in the first 1,000 miles?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 19taco4x4, Nov 16, 2018.
  1. Nov 16, 2018 at 9:22 AM
    19taco4x4
    19taco4x4 [OP] Well-Known Member
    Jesse
    21 Silver SR
    Hey Everyone,
    I read the break-in “rules and recommendations” about not towing etc and was curious to know if you could use 4Hi in the first 1,000 miles? I have never had a 4x4 before, so this might be a noob question. Thanks in advance!
  2. Nov 16, 2018 at 9:25 AM
    tcjacado
    tcjacado Well-Known Member
    Yes you can use 4x4. It is recommended that you put it in 4wd for at least 10 miles a month just to keep everything lubed and working. Go find some dirt and exercise it. If no dirt.... find a nice long stretch of pavement. Be careful turning on pavement in 4wd as the steering can bind up on to sharp of a turn.
  3. Nov 16, 2018 at 9:26 AM
    BlueFalconActual
    BlueFalconActual Some dude
    2017 DCSB TRD OR 4x4 MT
    As stated above, I personally would recommend using it as part of the break in process.
  4. Nov 16, 2018 at 9:27 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Why can’t you tow with a new truck?
    19taco4x4[OP] likes this.
  5. Nov 16, 2018 at 9:28 AM
    tcjacado
    You can, but it is not recommended.
    19taco4x4[OP] and Taco_Coma like this.
  6. Nov 16, 2018 at 9:29 AM
    PackCon
    Connor
    But why?
    What is different about a new truck vs one with 100,000 miles?
    Geniune question.
    19taco4x4[OP] and TFly like this.
  7. Nov 16, 2018 at 9:31 AM
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    I took mine off road on the way home from the dealer. It is not recommended that you use 4x4 on pavement so find some dirt or depending on where you live snow.
    There was a tread a while back about this same subject. I'll see if I can find it for you.
  8. Nov 16, 2018 at 9:31 AM
    hammerd
    hammerd New Member
    Darrell
    Indiana
    2018 Tacoma TRD OR DCSB - Cement
    New trucks have new ring and pinion gears, which haven't fully mated with one another. It's during this break-in period that the gears mesh through heat cycles and a small amount of wear. The manufacturer recommends you not tow while all of this is going on, because it exacerbates the generation of heat which can damage the fluid and/or gears.
  9. Nov 16, 2018 at 9:32 AM
    tcjacado
    The engine and drive train should have some milage on it before putting it under that kind of stress. Best I can give you..... I personally feel as you do. Use the truck for it's intended purpose right off the lot if you need to. Shouldn't hurt anything.
    I used to break in my vehicles by going on a long trip and getting it up to 100 as frequently as possible and never drop below 80.
  10. Nov 16, 2018 at 9:33 AM
    Mountain Minstrel
    Prather, CA
    '17 DCSB MT INFERNO
  11. Nov 16, 2018 at 9:34 AM
    tcjacado
    Fixed.
    Let's not go through this again :rolleyes:
  12. Nov 16, 2018 at 9:36 AM
    SouthtownTaco
    SouthtownTaco Well-Known Member
    San Antonio, TX
    2016 TRD Offroad
    RCI Under Armor, Tailgate Lock, Bakflip F1, derped grill
    I used it in the first 5 miles! It's made for it. Be gentle but use it all!
    19taco4x4[OP] and Kilokato like this.
  13. Nov 16, 2018 at 9:38 AM
    Mountain Minstrel
    Prather, CA
    '17 DCSB MT INFERNO
    need more coffee.:anonymous:
  14. Nov 16, 2018 at 9:48 AM
    PackCon
    Connor
    I understand older vehicles required special brake in procedures but didn’t think that applied to modern vehicles.
    If I used my truck aggressively right away I may change some fluids early but brand new shouldn’t work less well than old.
  15. Nov 16, 2018 at 10:06 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Bedding the brakes. Light duty cycles to begin with.
    Every machine is like this.
    shakerhood and 19taco4x4[OP] like this.
  16. Nov 16, 2018 at 10:19 AM
    19taco4x4
    Jesse
    21 Silver SR
    Thanks, I appreciate the info. The Northeast where I live got some snow and was curious if I could use it or not for the first time. The roads were wet, some slightly slush and chunk covered. I was easy with it as first time use. Thank you!
    Thanks! I appreciate the info.
    Thank you, I appreciate the info.
    Thank you, I appreciate the info. I will have to read through the thread.
    tcjacado[QUOTED] likes this.
  17. Nov 16, 2018 at 10:35 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Don't forget to pregrease your zerks!
