4X4 indicator light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stumpy555, Jan 18, 2022.
  1. Jan 18, 2022 at 11:02 AM
    stumpy555
    stumpy555 [OP] Member
    2005 tacoma 4x4 with the differential lock button. Niether work and the 4x4 indicator light on dash is blinking. Is there a typical problem that I should look at first or is it anyones guess
  2. Jan 18, 2022 at 11:13 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Dm93 and llamasmurf like this.
  3. Jan 18, 2022 at 11:20 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The diff lock will only function in 4 Low, the flashing 4wd light indicates the 4wd ECU was unable to complete a shift or a limit switch is out of the expected range.
    Withe the age of the truck it would be a good idea to check the vent hoses on the actuators, if either is disconnected water and dirt can get inside and mess up the contacts, sometimes they can be taken apart and cleaned other times they must be replaced.
    Alot of info about the system compiled in the thread @TnShooter posted above.
    TnShooter and llamasmurf like this.
  4. Jan 18, 2022 at 11:20 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    @TnShooter is right, start there.
    You need it to engage 4L before you can turn the locker on.
    Dm93 likes this.
  5. Jan 18, 2022 at 11:22 AM
    10YSON
    10YSON Well-Known Member
    GREG
    TACOMA & 4RUNNER
    TOTAL CHAOS / KING / DEAVER / PRP / DIRTKING
    If you need some encouragement; I was able to fix my 4wd system with the info here on the forum and now it works great.
    llamasmurf, Dm93 and TnShooter like this.
  6. Jan 18, 2022 at 1:53 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    First things first. KISS METHOD.
    Like stated you need to be all the way in 4lo for the rear locker to work (stock thats how the system is).
    To get into 4lo you must be FULLY into 4hi first, be under 3mph in neutral (auto) or clutch fulllly depressed (manual) then shift to 4lo.
    To get into 4hi you can shift from 2hi to 4hi under 60mph on the fly (recommend to be rolling around 10mph or so in a slight arc).
    If you cant get into 4hi, you wont be able to get into anything else.
