4x4 Issues, Front diff actuator or t-case actuator?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 99GreenYota, Jan 6, 2015.
  1. Jan 15, 2015 at 9:23 AM
    #41
    99GreenYota
    99GreenYota [OP] Well-Known Member
    Dan
    Devner, CO
    06 Tacoma V6 TRD Sport
    To many to list...
    With that said, the truck is now drivable and I think in 2 wheel drive. I would like to take off the t-case actuator again this weekend and do some tests on it. Does anyone know how to test the motor while it is off the truck? I heard of someone connecting it straight to the battery to see if it would actually run. Is this the proper way to test to see if it works? Other then that, I read there could be some issues getting the actuator aligned back to the t-case. I attached 2 pictures of the actuator taken apart, let me know what you all think.
  2. Jan 15, 2015 at 10:59 AM
    #42
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
  3. Jan 15, 2015 at 1:34 PM
    #43
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Good call. I guess they are 12mm, my bad. ;)
  4. Jan 19, 2015 at 7:44 AM
    #44
    99GreenYota
    Dan
    Devner, CO
    To many to list...
    Well tore apart both actuators this weekend to find out that they were both in working order and found the problem to be a small gear inside the front actuator assembly. See attached image. We notice after testing that because 3~4 of the teeth were broken off it would not turn the larger gear which engages the front. Since it was just turning in there it never engaged the front and the computer never told the transfer-case it was ready for 4WD. Actually all quite interesting once we got it figured out. With that said, since they don't sell the gear separate I think I'm going to try and 3D print it since the only other option would be purchasing the entire front actuator assembly. Ill let you guys know how it turns out and if it works!
    Also attached is an image if anyone gets themselves into trouble by taking the entire t-case actuator apart like I did and have no idea how to get it back together. Just a heads up, if the gears do not go back together correctly your 4 wheel drive will be all off. Make sure to line up the metal contacts as shown with the arrows. Hopefully that helps everyone that was as confused as I was.
    TheMuffinMan and DC92T like this.
  5. Jan 26, 2015 at 7:37 AM
    #45
    99GreenYota
    Dan
    Devner, CO
    To many to list...
    Hey guys, I wanted to let you all know the 3D printed gear was a success! The install went perfect and has been working for a little over a week. Going this route also saved me a ton of money not having to buy a whole new actuator! If anyone else has this gear go out I have the files uploaded on a site where you can get them printed for $15. Feel free to hit me up. Thanks again for everyone's help!
    TomHGZ, cryptolyme, WRDD Taco and 2 others like this.
  6. Jan 26, 2015 at 9:53 AM
    #46
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Interesting. I wonder how long the plastic gear will last if the steel one broke?
  7. Jan 26, 2015 at 11:03 AM
    #47
    99GreenYota
    Dan
    Devner, CO
    To many to list...
    The original was nylon plastic material. All the gear in the actuators were. We tested the original vs. the 3D printed part for hardness and strength and both came out to be fairly similar.
    HappyGilmore likes this.
  8. Jan 26, 2015 at 12:22 PM
    #48
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Very cool, good job locating the issue and coming up with an economical solution! Could you update with a report on more longer term durability in a few months? I'm curious as to the durability in varying temperatures, etc.
    winkel likes this.
  9. Jan 26, 2015 at 12:37 PM
    #49
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I didn't know that, pretty neat that you can replicate it so easily. I wonder how common the broken gear thing is? Most people just replace the whole assembly without investigating why the old one is kaput.
  10. Feb 27, 2015 at 6:04 AM
    #50
    Milepond
    Milepond New Member
    2005 Tacoma 4x4
    My Son was tapping on Tcase actuator and broke nipple on vaccum hose, will i have to buy WHOLE thing?? $1200.00 T case actuator sounds like it is operating but front one has no sound when turning switch.. it is stuck in 4 high,, it will go to 4 low and back to high but wont go to 2 hi. I am lost!!!!
  11. Feb 27, 2015 at 7:23 AM
    #51
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    That's just a vent hose. Get some quicksteel and put the nipple back on there. You can manually shift it into 2HI. Push the shift shaft (the thing the T-case actuator is hooked on to) all the way in. One click out is 4hi, two clicks out is 4lo. You can repair both actuators. Read through this thread and you will be an expert on how to do so.
  12. Mar 14, 2016 at 6:58 AM
    #52
    Fedupdon
    Fedupdon Active Member
    Arlington tx
    05 4x4 dbl cab
    None yet
    i have a 05 tacoma that has been giving me hell it started out not shifting in to 4 wheel drive .replaced the front actuator still no 4 wheel drive replaced the transfer case actuator now have 4 lo but no high the mechanic thinks its a timing issue with the transfer case motor any one how to check the timing or could it be the sensors
  13. Jan 1, 2018 at 10:04 PM
    #53
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    this exact thing happened to me tonight in my 1st gen (although my 4wd light won't come on at all). OP are you still out there? if I need a 3D printed part can you help me?
  14. Dec 3, 2018 at 5:20 PM
    #54
    DC92T
    DC92T Well-Known Member
    03 TACO 33" BFD's SLOWPOKE
    Suspension lift, towing package with air bags rolling on 33" BFG A/T's
    THIS POST!! - Got me up and running today, THANK YOU!! I searched for DAYS....
    I couldn't find an "alignment" post/topic.
    I'll update my NEWB post for clarity soon because everyone has 4WD issues, but MANY don't post the result, the fix, actual repair when done...
    TheMuffinMan likes this.
  15. Jan 27, 2019 at 10:49 AM
    #55
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    2019 checking in, time to repair my 4WD hahaha!
  16. Feb 14, 2019 at 2:06 PM
    #56
    arwinnnsd
    arwinnnsd Rockin the Death Train!!!
    Alexander
    Woo, MA
    The Death Train!!!
    BFG All-Terrain KO2s Pelfreybilt Al triple loop plate bumper Warn Zeon 8-S winch EBC Brake Kit - S5 Yellowstuff and GD Rotors Custom kick out rock sliders
    Hey all,
    So I already took apart and soldered my 4wd ADD actuator. The 4wd light is still blinking, but oddly now I can switch back and forth between 2 and 4wd, BUT only when starting the car. If I turn the knob while the car is running nothing happens. But if I turn off the car, and turn the key as to not start the car, I can turn the knob, start the car and I'll be in the selected drive every time.
    I have dug around several posts for the last two weeks and I haven't found any case similar. Does anyone know whats going on or have a link to a post i possibly missed?
    I.am.broccoli likes this.
  17. Feb 14, 2019 at 2:15 PM
    #57
    socalexpeditions
    Sounds basic but have you tried removing the battery cables and resetting the computer?
  18. Feb 14, 2019 at 2:19 PM
    #58
    socalexpeditions
    Try letting it sit without touching the battery for a good bit
  19. Feb 14, 2019 at 2:31 PM
    #59
    arwinnnsd
    Alexander
    Woo, MA
    The Death Train!!!
    Yeah didn't work, I disconnected the battery for a little over 24 hours and no luck, still blinking...
  20. May 17, 2019 at 10:45 AM
    #60
    I.am.broccoli
    I.am.broccoli Member
    Brock
    2008 TRD SPORT
    Na
