4x4 Issues, Front diff actuator or t-case actuator?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 99GreenYota, Jan 6, 2015.
  1. Oct 25, 2024 at 1:36 PM
    #81
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'll have to take a look tonight when I get time, if you could fill out 2H and 4H sections of the pin voltage chart in the thread I have linked and post it here that would help me see where everything is and where we need to check first.
    303tacoma likes this.
  2. Oct 25, 2024 at 4:28 PM
    #82
    Offthewall
    Offthewall Well-Known Member
    Southern OR
    12 tx pro
    That’s why I’m here
    I have it written out but for some reason it won’t load the picture. The only 2 reading that are off is tl1 and tl2 which read as they would if it was still in 2wd
    So after reading more i believe it to be the inside readings of the transfer case actuator not reading properly
  3. Oct 25, 2024 at 5:07 PM
    #83
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So TL1 & TL2 aren't changing but 4WD is correct at 12v in 2wd and 0v in 4wd?
  4. Oct 25, 2024 at 6:06 PM
    #84
    Offthewall
    Southern OR
    12 tx pro
    That’s why I’m here
    The voltages are not changing, and staying correct for 2wd. Even though the transfer case is shifting to 4wd
  5. Oct 25, 2024 at 6:10 PM
    #85
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So 4WD is switching like it should?
  6. Oct 25, 2024 at 6:24 PM
    #86
    Offthewall
    Southern OR
    12 tx pro
    That’s why I’m here
    Yes it is changing,
  7. Oct 25, 2024 at 6:44 PM
    #87
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Very odd that both TL1 and TL2 aren't changing at all being we know the actuator is moving, I would expect at least one to change.
    In any case we need to check circuit integrity, unplugh the Transfer Case Actuator and verify they both go to 12v then use a small paperclip or other suitable tool (no larger than the male terminals) to jump them each to Pin 4 (White/Black) of the actuator connector one at a time and verify they go to 0v at the ECU when jumped.
    TL1 is Pin 5 (Blue/Yellow) and TL2 is Pin 6 (Blue/White) at the actuator connector.
    If that checks out then the issue has to be with the contact plate in the actuator.
  8. Oct 25, 2024 at 7:10 PM
    #88
    Offthewall
    Southern OR
    12 tx pro
    That’s why I’m here
    I already had the actuator out of the truck earlier and sanded down the contacts, and regreased it.
    Just went out to the shop to try your suggestion and decided to re check the values. I apparently fixed tl1 and 2 with my sanding, but still flashing on the dash.
    ADD is reading 11.9 in 4wd, and it seems that it was probably reading that before. (Had to wiggle the probe around to get a reading, guessing I took the 0.0 for granted before)
    Is the ADD reading from the detection switch in the actuator?
  9. Oct 25, 2024 at 7:19 PM
    #89
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So now the only value that is incorrect is ADD?
    Are DL1 and DL2 correct?
    ADD is the ADD Detection Switch in the ADD Actuator on the front axle, it's the feedback for the physical position of the axle disconnect (open (12v) when disconnected (2wd) and closed (0v) when connected (4wd)).
  10. Oct 25, 2024 at 7:27 PM
    #90
    Offthewall
    Southern OR
    12 tx pro
    That’s why I’m here
    Yes dl1 and dl2 are reading correct, although dl1 is only reading 11.8
  11. Oct 25, 2024 at 7:43 PM
    #91
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So the actuator is moving at least some.
    Have you checked if the front axle is locked in when in 4wd?
  12. Oct 25, 2024 at 7:49 PM
    #92
    Offthewall
    Southern OR
    12 tx pro
    That’s why I’m here
    The actuator is moving the whole way. Im guessing that little switch is bad. Had the add actuator out to manually engage 4wd at the dunes a couple weeks ago.
    that little arm had popped out but i put it back together. Then when i was doing my testing it took me to the back, I guess it was both
  13. Oct 25, 2024 at 7:55 PM
    #93
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You can check circuit integrity the same way, jump Pin 3 (Light Green/Black) to Pin 4 (White/Black) and verify ADD goes to 0v at the ECU.
    If the circuit checks out and the axle is locking but ADD isn't switching in then the issue is likely in the ADD Actuator.
  14. Oct 26, 2024 at 6:51 PM
    #94
    Offthewall
    Southern OR
    12 tx pro
    That’s why I’m here
    Yep wiring checks out, 0v when jumpered. Gonna get a new actuator and see if i can find a used add someone has laying around to use parts to rebuild a spare.
    Thank you for the help, i was headed down the wrong rabbit hole for a minute there.
    Dm93[QUOTED] likes this.
  15. Oct 26, 2024 at 7:16 PM
    #95
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    There's probably quite a few good ones that end up in the trash with the shotgun parts method of troubleshooting so many people do.
    No problem
    That's why I took the time to take a deep dive into how the system works to develop a test plan that gives us a very good shot at finding the problem component (or at least having enough evidence to take something apart to inspect) on the first go rather than taking apart/replacing components and hoping you got it right.
