4x4 light flashing when starting the truck 4x4 inop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcoopdujour, Aug 14, 2010.
  1. Aug 14, 2010 at 10:33 AM
    bcoopdujour
    bcoopdujour [OP] Member
    Brendon
    Surf City, NC
    08 Double Cab 4x4 3" Toytec lift 33" BFG Muds
    3" Toytec Lift
    I apologize if this has been posted before however I did search but no joy. Here we go:
    I jumped in my truck to drive to my buddies house the other day and I noticed the green 4x4 indicator light was flashing like it does when trying to engaged four wheel drive. I pulled over took an overall look at things tried engaging/disengaging a few times, truck on/off but no luck. The usual clunk of the transfer case and the solenoids clicking didn't happen either it was like I hadn't moved the switch just a flashing light. I haven't used 4x4 in weeks however did just drive it 700 miles or so. Anyway, I turned into his development and noticed the light was out. The four wheel drive then seemed to work fine. I assumed it was gremlins.
    At work yesterday driving around base same thing flashing light, 4x4 inop. Now I'm just pissed and ignoring it. Got lunch, start truck up lights out 4x4 works. I believe at one point I turned 4x4 knob and nothing happened at all.
    My guess is obviously electrical issues, however I read in another post about some vacuum lines that actuate the front axle. I'm hoping it's still under warranty for one and thinking it's probably not something mechanical like the T-case or front axle components. Any thoughts, hints or insight into my problem would be greatly appreciated.
    If it makes a difference I've got a 3 inch toytec lift with 275/85/R16's on it and have but have yet to install the light racing upper control arms.
    Thanks,
    Brendon
  2. Aug 14, 2010 at 10:40 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    So, you are usually always in 4WD... and the light is usually always on?
  3. Aug 14, 2010 at 12:16 PM
    bcoopdujour
    Brendon
    Surf City, NC
    3" Toytec Lift
    No I'm rarely in 4wd except when four wheeling. The light just came on randomly while driving on pavement with the selector in 2wd.
  4. Aug 14, 2010 at 2:04 PM
    David K
    Then you have a problem!
  5. Aug 14, 2010 at 6:25 PM
    bcoopdujour
    Brendon
    Surf City, NC
    3" Toytec Lift
    thanks for your insight....
  6. Aug 14, 2010 at 7:07 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    When my 4wd light flashed constantly and the truck would not go into 4wd or 4 lo it was my actuator. Toyota covered it under warranty. Mine went out at 16k, truck was stock and used 4wd a lot on the winter roads up here. It just happened out of the blue like you described.
  7. Aug 14, 2010 at 8:15 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Your most likely culprit is 4wd switch in transfer case. Check that first.
  8. Aug 30, 2010 at 7:28 PM
    bcoopdujour
    Brendon
    Surf City, NC
    3" Toytec Lift
    So I got the truck to the dealership and after messing with it all day they determined it was the 4 wheel drive actuator at the center differential. Exactly what I told them I thought it was. Anyway, they have to order the part and have yet to determine if it's a warranty item. Anyone have experience here. I would consider it a drive-train item and I'm under 60k so that should be covered as I see it. But I'm the guy that doesn't want to shell out a ton of cash. Regardless, that things should not be going bad at 47k on a 2008. If I have to go to bat here anyone with experience having this thing warranteed I'd appreciate it.
  9. Aug 30, 2010 at 7:30 PM
    98tacoma27
    Ben
    Not Beech Creek
    Um, look two posts up from yours
  10. Aug 30, 2010 at 7:33 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Why would they order it if they weren't going to warranty it?
  11. Aug 30, 2010 at 9:38 PM
    Ipunchwalls
    Ipunchwalls Well-Known Member
    Brian
    Colorado
    mine just did the same thing, it was the actuator, it cost $1600 to replace...they apparently had to remove my front suspension. That's at the dealership of course, I had to have it fixed asap, and they did had it less than a day, so I guess I can't bitch too much. Also I think I killed mine after getting stuck in water up to just below my doors. This is with a 6" lift and 33's...
  12. Aug 30, 2010 at 9:50 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Yeah, Toyota likes to replace them if it doesn't work right away... What happens a lot is that water will work its way into the actuator. All it requires is a disconnect to clean her out. That has been the case on most that I have looked at. But my cousin also had his completely seize up... So I guess there's a lot of variables that could be in play here.
  13. Aug 31, 2010 at 5:54 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    yeah mine would not work at 16k during our mud season.
    Truck was stock, no river crossings, normal driving a 4wd truck in rain & snow, 4WD used regularly on Class III & IV roads getting to camp & to the mountains. The part was around $350 plus the diag fee & install. Toyota paid for it & its fine since 50k on the truck now.
  14. Aug 31, 2010 at 6:19 AM
    bcoopdujour
    Brendon
    Surf City, NC
    3" Toytec Lift
    Thank you for all your responses. Anyone had any experience replacing this thing on their own? I have access to a lift. I'm not thrilled about dropping $1600 bucks if I can replace it myself
  15. Aug 31, 2010 at 7:15 AM
    bcoopdujour
    Brendon
    Surf City, NC
    3" Toytec Lift
    So I just crawled under the truck and popped off the skid plate. Unless I'm mistaken it's sitting right there and quite accessible. I'm still waiting to hear what they come back with as far as warranty and/or quote for the part/work. Conicelli has it for like 280 bucks. We'll see. If it's outrageous I just found something to do this weekend....
  16. Aug 31, 2010 at 7:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    Here is what you would be looking at. See step #4 and #34
    Mr x 1979 likes this.
  17. Aug 31, 2010 at 7:56 AM
    bcoopdujour
    Brendon
    Surf City, NC
    3" Toytec Lift
    I was just looking at the same pages. Thanks for your help.
  18. Aug 31, 2010 at 8:21 AM
    bcoopdujour
    Brendon
    Surf City, NC
    3" Toytec Lift
    Update..
    Toyota of Wilmington just called and they're going to warranty the part. Sweet...
  19. Aug 31, 2010 at 10:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    Best news yet!!!!
    :cheers:
  20. Apr 12, 2012 at 7:02 AM
    cc tacoma
    cc tacoma Member
    Cooper
    Prescott, Az.
    2009 Mag Grey Double Cab 4x4 Sport
    Hello fellas,
    I just did a search on this forum because my 09' with almost 25k miles is doing the exact same thing. I'm going to take it in this week. If they don't cover it Im going to freak out!:boom:
