4x4 light will not come on.help
Discussion in 'Suspension' started by linda tryan, Feb 23, 2013.
  1. Feb 23, 2013 at 5:04 AM
    linda tryan
    linda tryan [OP] Member
    lyn
    michigan
    07 tacoma 4wd TRD
    1998 toy 4x4 auto trans auto hubs.looked under truck saw cv joint on left side was leaking grease bad.tried the 4wd and would not go into 4wd no 4x4 lihgts on dash and will not lock in front dif.anyone know if bad cv joint can cause this problem?any help would be great Thanks
  2. Feb 23, 2013 at 5:07 AM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    I would say a bad CV will not cause this all my cvs are torn and i have no problem with 4x4. I have never heard of a problem like this before.
  3. Feb 23, 2013 at 5:28 AM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    check your fuses/4wd relay/box? had a friend who bought a 4x4 4runner. the guy he bought it from said the 4wd didnt work. got to looking around and found out the fuse was blown. worked like a charm ever since.
  4. Feb 23, 2013 at 5:29 AM
    GotLift37
    North East AL
    07 4Runner 4WD
    maybe the wire is unplugged from the switch behind the dash?
  5. Feb 23, 2013 at 5:30 AM
    gearcruncher
    Canadain bumper technician
    I cant remember how 4 wheel drive is driven on the 98 but I beleive there is an actuator on the front axle .The front axle Could be vacuum controlled or could be electrical ...dont remember
    When you select 4 wheel drive on the transfer case , 12 volts is applied the the actuator on the front differential to move a shift fork to the 4 wheel drive position .
    Once the shift fork on the front axle locks into the 4 wheel drive position , the light will illuminate .
    Using a test light , Test for 12 volts at the front differential actuator when you shift the transfer case into 4x4 .
    A torn cv boot will not cause you to lose 4x4
  6. Feb 27, 2013 at 3:49 AM
    linda tryan
    lyn
    michigan
    07 tacoma 4wd TRD
    gearcruncher.THANKS for the help.hundreds of people on this site and you were the only one who had any idea about this problem.THANKS LYN TRYAN
  7. Feb 28, 2013 at 4:36 PM
    gearcruncher
    Hey , no problem . Thats why I am here ...:)
    So was the front differential actuator the problem ?
    Did you have 12 volts at the wiring harness at the front actuator harness or is this vaccuum controlled ?
    I have more diagnostics for you if need be . Let me know
