4x4 low wont disengage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shaneh39, Aug 6, 2011.
  1. Aug 6, 2011 at 10:28 PM
    shaneh39
    shaneh39 [OP] Member
    Washington
    07 4x4 sr5 black
    Just purchased. Stock with ARE canopy
    I did a little 4x4 ing today. My clutch got a a little hot saw some smoke and could smell it. When I went to disengage 4x4 low the buzzer went off. I tried driving forward and reverse and ended up having to drive home in 6th gear at 30mph. Disconnected the battery for 2 hours and restarted in 2h with no results.
    It is a 2007 access cab manual 6 speed with 55k miles. Any suggestions before I pay a mechanic?
  2. Aug 6, 2011 at 10:36 PM
    shaneh39
    Washington
    07 4x4 sr5 black
    I have used 4 low on 2 previous occasions but it was just a few feet and really nothing serious and yes I drove home about 10 miles like this in 6th gear
  3. Aug 6, 2011 at 10:42 PM
    shaneh39
    Washington
    07 4x4 sr5 black
    Thanks, had to push clutch fully in.
  4. Aug 6, 2011 at 11:57 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  5. Aug 6, 2011 at 11:59 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Um do you regularly shift without fully depressing the clutch? :notsure:
  6. Aug 7, 2011 at 12:25 AM
    kauaibuilt
    kauaibuilt U no kea but AINOFEA!
    LA/SGV
    2011 DCSB
    Check out my sig...
    I had the same problem. Ended up going to the dealership jsut for htem to let me know how retarded I am.
    You only HAVE to push the clutch down about 1/2 - 3/4 way for it to disengage to shift, you need to push it to the floor to disengage 4Lo.
  7. Aug 7, 2011 at 12:32 AM
    BoostingMS6
    BoostingMS6 Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    You really should be pushing the clutch all the way in regardless.
    Edit: The bold speaks for itself.
  8. Aug 7, 2011 at 12:41 AM
    kauaibuilt
    LA/SGV
    2011 DCSB
    Check out my sig...
    2 different issues.
    1. x-case wont let you change out of 4lo w/o fully depressing the clutch pedal.
    2. the point where the clutch disengages within the transmission is not with full clutch pedal depression, theres a decent amount of play.
  9. Aug 7, 2011 at 12:48 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    :facepalm: lazy ppl, press ur clutch all the way in
  10. Aug 7, 2011 at 1:16 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    I was always under the impression this is the best way to burn up your clutch and cause excessive wear?
    When driving a manual I only shift with it fully depressed...
  11. Aug 7, 2011 at 1:20 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Umm, call me the stupid one here, but how in the hell are you needing to use the clutch enough to smoke it if you're in 4LO.... I mean, you must be riding that damn thing. Sounds like you need to learn some things about driving a clutch IMO....THEN worry about 4 wheelin.
  12. Aug 7, 2011 at 1:25 AM
    brian
    Elizabeth City, NC
    Not true. I'm not an expert on how things work, but it keeps the gears turning enough to aid in a smoother shift. I drove a lot of large trucks and you will never get anywhere putting the clutch to the floor because the gears won't line up. Clutches will naturally build some heat. Riding the clutch is a different story, and sounds like what he did.
  13. Aug 7, 2011 at 5:43 AM
    SilverTacoZack
    SilverTacoZack Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    Its only going to hurt your clutch if you are not past the engagement point. Most clutch pedals have a good bit of dead travel at the end. If you have pushed the pedal down enough to fully seperate the clutch plate from the flywheel, it doesn't matter if it was to the floor or not. That having been said, when I had my 6 speed manual BMW 330i, I always pushed the clutch all the way to the floor because it had a moving engagement point due to some wierd design, so you never knew that point exactly.
  14. Aug 7, 2011 at 11:29 AM
    Eman5pt0
    Eman5pt0 Well-Known Member
    E
    NY
    :burnrubber::thumbsup::thumbsup::thumbsup:
