4x4 making noise while driving in snow.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fabulous, Dec 7, 2009.
  1. Dec 7, 2009 at 2:49 PM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Hey guy's/ gals...quick question. I have a 06 TRD Sport with the 6 speed, and just this past week have I had to use the 4x4, and I have been noticing almost a mechanical whine noise from the truck while driving...is this normal on the Tacoma? My old 4Runner had the old stick style shift to engage, and it made no noise while driving...I'm curious. Any help is appreciated.
    Thanks.
  2. Dec 7, 2009 at 3:06 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Are you in 4HI when it's doing this? Also, is there a lot of wheel slippage when you're going?
  3. Dec 7, 2009 at 3:08 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I have an 06' TRD Sport but an automatic and I dont use the 4x4 alot but if I remember correctly, mine also whined while in 4low.:rolleyes:
  4. Dec 7, 2009 at 3:20 PM
    Fabulous
    Fabian
    Calgary, AB
    It's while in 4 High. It's like a mechanical whining noise, but the wheels aren't really slipping. It's a lot louder than while in 2 High.
  5. Dec 7, 2009 at 3:55 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    check oil level in front diff, grease the front drive shaft?
  6. Dec 7, 2009 at 4:22 PM
    Fabulous
    Fabian
    Calgary, AB
    I just had an oil change, and they checked all that...said it was fine. Maybe they f-ed up?!
  7. Dec 7, 2009 at 4:39 PM
    skistoy
    Western New York
    They would have to open up the diff to check level, never seen them do that on a oil change unless they charge you extra for that. The same with greasing the drive shafts. These are simple checks though, if you got a dry and hopefully warm place to do. A small grease gun is fine for doing the drive shafts, as long as your not in 4wd, you can spin the front drive shaft to get to the zerk fittings. you will have to roll the truck to get the back down.
    The whine may be just normal, but i would still check the diff to be sure.
    Also engage the 4wd every month to keep everything lubed and working.
  8. Dec 7, 2009 at 4:46 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    Yeah, check yourself or have a truck place do it. The speedy lubes of the world are never going to do that.
    Might as well do both the front and rear diffs...and like skistory said, lube the shafts.
  9. Dec 8, 2009 at 10:02 AM
    Fabulous
    Fabian
    Calgary, AB
    Guess I'll have to take it to the dealer to have it checked. I bought the truck used with 85,000 kms on it, and had it fully checked out by Toyota, and the previous owner had a reciept from 82,000 kms that said that the 4x4 was checked, and lubed?! Is this sort of thing pretty simple...like it's not gonna cost me an arm and a leg, right?
  10. Dec 8, 2009 at 10:13 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Mine has that slight whine in 4x4 at 55mph, I think its a normal thing.
  11. Dec 8, 2009 at 10:17 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    '10 TRD SPORT Acc.Cab Mag Grey 4x4 Auto
    Weathertech floor liners, stone and bug deflector, Putco Element In Channel Window Visors, Viper remote starter, Harley lighted hitch cover, Herculeze front mudflap, Metal Miller Harley Grill Emblem, SockMonkey design Bedside Decals and 3rd Brake light TRD decal, K&N Air Filter, Goodyear Duratrac 265/70/17 C load, Valor Exhaust tip, De-badged tailgate, Advantage Tonneau Cover, Tacoma bedmat, Bicycle Mount Rail mounts, Custom Ipod holder. Stock Suspension :( (winter wheels: 2014 16" stock steel wheels plastidipped black with general arctics 265/75/16)
    If the dealer is checking for something they said they checked, they shouldnt charge you again.Take the service guy for a ride and show him, point out what you are hearing. they should know if it seems normal.
  12. Dec 8, 2009 at 10:32 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    Its prolly the tcase. mine whines. its the gears. in 4lo the gears spin as if you are in 4hi at high speeds. there isa gear reduction in 4lo but the input shaft is spinning the same speed as in 4hi.
    Ex. if it whines at 15mph in 4lo then it will whine in 4hi at 45mph
    Like in 4th gear the ratio is 1:1 through the tranny so 2000rpms on the engine the tranny turns 2000rpms. When in 4x the tcase will run other gears to turn the front drive shaft. so 2000rpms in 4hi and 2000 in 4lo will both whine but in 4lo the gear reduction adds noise and the wheels turn much slower. with 4hi your going much faster so you dont notice the noise much.
  13. Dec 8, 2009 at 12:33 PM
    Fabulous
    Fabian
    Calgary, AB
    The whine on mine is noticable at about 60 km/h on up, and gets more pronounced as you step on the gas. I am just worried because my 1993 4Runner never made a noise as pronounced, although it did make some noise, but very faint. Maybe I'll take it to Toyota, and have them go on a little ride to check it out...
  14. Dec 8, 2009 at 2:47 PM
    Negative1
    Negative1 Well-Known Member
    X2.
    Perfect explanation, I was going to allude to the same thing, just explained differently. It's normal, dont worry about it... gears moving.
  15. Dec 8, 2009 at 2:48 PM
    IrishPilot
    IrishPilot Well-Known Member
    MN
    09 TRD Off-Road 4x4 Double Cab
    Mine did the same today. In the process of 8-15in of snow. MN Blizzard FTW. I LOVE my 4x4.
  16. Dec 8, 2009 at 3:04 PM
    SubZombie
    SubZombie Well-Known Member
    South East
    09 DC TRD Off Road 4x4 Barcelona Red
    Is it only while in the snow?
    I've never had mine make any noise like that...but I have an Auto.
  17. Dec 8, 2009 at 3:44 PM
    Fabulous
    Fabian
    Calgary, AB
    I haven't really had any other reason to use the 4x4 for any extended periods of time, so I never really noticed I guess. I snowed a fair amount, then got all packed down to near ice, so I had to use it...that's when I noticed. It's not super loud or anything, but I'm the kind of person that any little sound makes me freak unless I know what it is. If I have the heater/ fan on medium I can't hear it anymore, so it's not loud...
  18. Dec 8, 2009 at 10:17 PM
    skistoy
    Western New York
    its probably normal. now put the truck into 4hi/4low once a month and you will get used to what it sounds like. Plus everything will get lubed
  19. Dec 9, 2009 at 12:03 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I just noticed, (but I'm not sure its normal at this point) my truck is alot quieter in 4HI than 2HI. It's actually really quiet once I throw it in 4HI. Even at up to 50 mph. I think I got some issues with my CV's or bearings though.
  20. Dec 9, 2009 at 7:30 AM
    Fabulous
    Fabian
    Calgary, AB
    Hmmm...weird. Mine is definitly louder when in 4HI than 2HI. Maybe it's a difference the auto, and the 6 speed?! I have to get an alignment soon, so I'll get them to check everything out, and lube it at the same time. If something is kaput, then my ECP will take care of it.
