4x4 messed up
Discussion in 'Technical Chat' started by Blacktaco2042, Nov 2, 2015.
  1. Nov 2, 2015 at 4:50 PM
    Blacktaco2042
    Blacktaco2042 [OP] Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    my buddy took his 15 taco thru a framers field and some water not sure how deep.
    truck covered in mud tho. was in 4hi and parked it. next morning he switched out it out of 4h and the 4wd light was flashing. its currently in 2wd but the lights are going crazy. tried hitting the actuators and nothing happened. tried undoing the batt same thing.
    we thinking that maybe he fried the front actuator.
    any ideas
  2. Nov 2, 2015 at 4:54 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Id be willing to bet the front actuator. I had the same issue before. If i turned off the truck and then turned the switch to H2, followed by turning on the truck it would kick back to H2. But it wouldnt engage h4 again except on occasion when the light would constantly flash therefore not letting it switch back to H2 or L4.
    Heres where i bought my replacement actuator
    http://www.toyotapartsdeal.com/oem/toyota~actuator~assy~diffe~41400-35032.html
  3. Nov 2, 2015 at 5:01 PM
    Blacktaco2042
    wisconsin
    yea it wont switch. i can get 4lo lights to light up but other then that its stuck in 2wd. i think it shifted out of 4wd and never seen the front unlock and now its confused and freaking out cause it not sure where the front is
  4. Nov 2, 2015 at 5:05 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Yea common problem. Mine had the same issues no matter what. Try turning off the truck with the switch on H2. Let it sit a few minutes then restart it, it may realize its in H2 at that point. But needs replacing
  5. Nov 2, 2015 at 5:15 PM
    Blacktaco2042
    wisconsin
    yea even letting it sit still flashes
    its a 2015 but i dont think the dealer will cover it since he was mudding it n it
    he ordered the part and ill slide it in tomorrow and hopefully that will fix it
  6. Nov 2, 2015 at 5:18 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'mwilling to bet you he didn't wash off his truck after the fact. I know a guy who butied his Tundra brand new and his alternator went out. Apparently what happened is he got mud lodged in the actual alternator itself so the internal brushes were not making electrical current, he ended up washing it all off and it worked good as new again. Lol.
    These reasons coupled with frame rust are exactly why I do not go mudding anymore.
  7. Nov 2, 2015 at 5:58 PM
    Blacktaco2042
    wisconsin
    yea the wheel wells are full but the underside isnt too bad but i just pick in the actuator and hope it fixes it
  8. Nov 2, 2015 at 6:28 PM
    Tacoma Mike
    Southern Maine
    Yea don't touch it. There may be nothing wrong with it
  9. Nov 2, 2015 at 7:05 PM
    Blacktaco2042
    wisconsin
    wish that was the case
    sunday it started first thing and when he put it in 2wd the light started flashing and hasnt stopped yet lol
  10. Nov 2, 2015 at 7:17 PM
    Tacoma Mike
    Southern Maine
    I see this all the time. Seriously, I've called like 3 or 4 people in the past year to talk them through getting it out. Every snow storm, same thing. Don't touch it and get the shop look at it. 95% of the time it's driver error and if it's confused they should be able to just drive it and work the system free. There is a set procedure and you cannot skip a step or it does stuff like this. Don't start replacing parts because you could create a worse issue. Plus it's under warrantee. Let them take care of it.
  11. Nov 2, 2015 at 7:24 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    And actuators go out too...the front one being notorious for it. Doesnt mean anyone is trying to switch it wrong. I knew mine was wrng with these exact symptoms, replaced it and havent had a single issue since. Id guarantee there is water in the actuator and the circuity is ruined.
  12. Nov 2, 2015 at 7:47 PM
    Tacoma Mike
    Southern Maine
    I'm not saying they don't go out. Im saying don't throw a part at it. Plus it's under warr.
    A 2015...... New truck, new owner. Seen it to often.....
    CroResident likes this.
  13. Nov 2, 2015 at 9:06 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Time for manual hubs and transfer case
