4x4 newbie question
Discussion in 'General Tacoma Talk' started by Javman, Jun 24, 2025.
  1. Jun 27, 2025 at 2:48 AM
    pjason23
    pjason23 Well-Known Member
    Phillip
    Alhambra
    2020 Taco TRD-Off Road 4x4 DBL Long Bed
    TRD Pro Grill TRD Raptor Lights Cali Raised LED Combo Spot/Flood LED bar & dual 27W Ditch Lights Black Rims Control Arm Lift 6’ Full Interior LED Light Upgrade Xeon Headlamp Bulbs Bakflip X4S2 Bed Cover Pedal Commander Fullly Upgraded 3 way active sounds system Arc Audio PS8 Pro & PSC controller Arc Audio X2450.4 amps x 2 Chanel 3/4 control mid and tweeter, Channel 1 &2 Bridged to Door speakers AudioFrog GS60 Door Mount, GS25 & GS10 in Custom Aluminum Pods Sound Deadining in doors by SOUND SKINZ Noico 80 mil & Noico loses Cell foam in the rest of the vehicle JL Audio 10 TW3-D4 x 2 wired to 1 oHm Audison S500.1 Amplifier Custom behind seat subwoOfer Boxes/ amp rack Custom Amp rack under rear seats Custom switches Performance Mods
    The only thing the manual said was to engage the 4x4 at least 1 time a month. not sure why but it's in the owners manual
  2. Jun 27, 2025 at 2:48 AM
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    easier said than done. I live in metro areas of New Jersey so trails or off road trails are hard to come by.
    soundman98 likes this.
  3. Jun 27, 2025 at 7:44 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    If you don't periodically use the actuator, it can freeze up. It's a use it or lose it kinda thing. If going long periods of time without going offroad, I usually just turn it on and off a few times on the freeway on a straight stretch. I seldom remember to do it monthly, but it gets enough use it's still going strong on my 14 year old truck. BUT, my e-locker actuator I pretty much forgot I have as I've only needed it like 4 times. And that 4th time it decided to die in the locked position. That was a fun drive home.
  4. Jun 27, 2025 at 11:06 AM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    There's off road trails in New jersey...
    https://www.onxmaps.com/offroad/trails/us/new-jersey
    https://www.nj.gov/dep/parksandforests/parks/whartonstateforest.html
    It's also completely possible to go out of state too (NJ isn't a huge state)...
    https://www.alltrails.com/us/pennsylvania/off-road-driving
    https://www.onxmaps.com/offroad/trails/us/new-york
    https://www.onxmaps.com/offroad/trails/us/maryland
    https://www.rc4x4.org/
    Even more can be had if you simply jump on your favorite internet Search Engine (Google, Duck Duck Go, etc.) and take a quick moment to research other areas around you. :)
  5. Jun 27, 2025 at 4:20 PM
    SenorTito
    SenorTito Well-Known Member
    Denver
    2016 TRD Sport DCSB MT | 1992 80 Series Land Cruiser
    RRW RR7-H, 285/70/17 General Grabber ATX, King 2.5s, Prinsu Roof Rack
    You could drive at highway speeds, make turns, etc.
    4H is usually only rated for a maximum of 55-60 MPH, but regardless you most likely don't need 4x4 just to drive in the rain - 4,500 lbs should have no problem staying in control on a wet road, and it would just add unnecessary wear to your system.
  6. Jun 27, 2025 at 4:33 PM
    Taco Ji
    New Jersey
    Well I need a reason to use it once a month as the manual says without having to go find some forest to drive on.
  7. Jun 27, 2025 at 4:39 PM
    SenorTito
    Denver
    A lap or two around the block will do just fine if you feel the need.
    Finding a beach or forest road never hurt either, that's what the warranty is for right?:thumbsup:
  8. Jun 30, 2025 at 6:59 AM
    Mr. Dallas
    Mr. Dallas Active Member
    Hubbard
    Texas
    2023 SR5 SX AC 4WD V6,'99 Tacoma SR5 5 sp. MT Xtracab; '06 Scion xB; '02 MR2 Spyder; '13 RAV4 LE
    I'm new at 4x4 as well (just bought my 2023 AC 4x4 on 04-01-2025) and am learning this stuff, too. Anyone that says that you don't ever need 4WD in the rain doesn't drive in the rain in TX. I have already been on I45 twice in central TX where it rained so hard there was 4-5 inches of rain on the highway and I couldn't see five feet in front of me. Driving like 20 mph. The only time I've heard WAZE say "flooded highway ahead". I would have survived, I think, with 2WD, but I sure felt better engaging all four wheels. When it rains here, it seems like the end of the world sometimes. Just my opinion.
  9. Jul 2, 2025 at 4:08 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    4X4 is designed to be used on slippery ground surfaces. Technically if driven short distances in a straight line dry pavement is OK, but I'd advise not doing so. When you corner each of the 4 wheels take a different track and need to turn at different speeds. The inside front wheel has the least distance to travel so it needs to turn slower. The outside rear wheel the greatest distance and needs to turn faster. When driving in reverse this is the opposite. In 2wd this isn't a problem as all of the wheels are free to turn at different speeds.
    In 4X4 all 4 wheels are locked together and the drivetrain tries to make them turn at the same speed. When cornering that inside front wheel needs to be able to spin slightly on the ground since it's now turning at the same speed as the others but has much less distance to travel. On mud, snow, ice, loose dirt, or gravel this doesn't hurt anything. On dry hard surfaces with good traction it puts the entire driveline in a bind. You rarely have a catastrophic failure but it's possible. Most likely things like the front CV Axles, U-Joints, and the transfer case will wear out much sooner than they should. You can probably get away with doing this a few times, but the more you do it, the sooner you break stuff.
    A lot of people confuse 4X4 with All Wheel Drive. AWD is a newer, more hi-tech system that sends power to all 4 wheels but allows them to turn at different speeds. It's fine on any road surface. In fact better on wet or lightly snow covered roads. True 4x4 is best in harsh off road driving but is pretty good in deep snow too.
    Low range doesn't give you more traction. It just reduces the gearing. I think Toyota uses a 2.5:1 reduction ratio. It varies by manufacturer with some having as much as 4:1 reduction. This makes it easier to pull heavy loads, and creep slowly up or down steep inclines or drive very slowly over rugged terrain without using the brakes as much.
    4X4 in reverse is fine. Wet pavement from rain is SLIGHTLY less damaging than dry pavement. If you're spinning wheels like on a wet boat ramp then 4X4 is OK. I don't advise using it just because it's raining. It's still causing excessive wear. Just not as much as on dry pavement.
    You need to drive in 4X4 occasionally in order to keep internal 4X4 parts lubricated. It also helps keep electrical components in working order. If you don't use 4x4 for months at a time parts don't get lubricated, and the truck may not engage into 4x4 when needed. A few miles/month is recommended but I don't worry if I miss a month occasionally. I find myself on a dirt or gravel road for a couple of miles almost every month and always engage 4X4 when I do. Some months I may only get in 2-3 miles in 4X4, I may skip a month occasionally and other months may see 200-300 miles in 4X4. The key is to use it regularly.
    Some guys get in their 4X4 use while driving on pavement in straight lines. Technically, and if you're very careful it can work but I don't advise it. Have a Brainfart, forget you're in 4X4 and make a 90* turn into a business or intersection and you could do some serious damage especially if that turn is made at some speed. It's not hard to find a dirt or gravel road to get in a little 4X4 usage to keep things lubricated.
