4x4 Noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ephesians_4_17-32, Dec 24, 2016.
  1. Dec 24, 2016 at 9:05 PM
    Ephesians_4_17-32
    Ephesians_4_17-32 [OP] Member
    Idaho
    '00 Tacoma 2.7
    Good evenin everyone, Lord willin you're havin a nice Christmas Eve whether at home or on duty.
    When I engage 4wd (hi), there's a thumping/metal clanging noise; happens in 1st & 2nd gear, and sometimes reverse. And especially when turning into a parking space. This happens only when I'm in 4-Hi. (1st Gen Tacoma; 2.7 manual trans)
    I appreciate any and all info you can suggest. No rush.
    Thank You!
  2. Dec 24, 2016 at 9:08 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    Do you run your transmission on a regular basis? How many miles are on it?
  3. Dec 24, 2016 at 9:12 PM
    Ephesians_4_17-32
    Idaho
    '00 Tacoma 2.7
    roughly 135k; and I only use 4wd in mud or snow, rarely have it engaged for over acouple days
  4. Dec 24, 2016 at 9:26 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    turning and 4x4 anything is a no-no. not a big no-no, just a no-no.you can damage something that way. other than that, a clunking noise while engaging is kinda normal.
    when you engage 4x4 hi or lo, is the clutch fully depressed? or do you just gun-ho it while moving?
  5. Dec 24, 2016 at 9:30 PM
    Ephesians_4_17-32
    Idaho
    '00 Tacoma 2.7
    clutch is fully depressed; no gun-ho haha, it's my daily driver - can't afford to have her outta commission
  6. Dec 24, 2016 at 9:31 PM
    CodeSeven
    Serge.
    Coachella Valley
    has it been doing this for some time or just recently?
  7. Dec 24, 2016 at 9:37 PM
    Ephesians_4_17-32
    Idaho
    '00 Tacoma 2.7
    just recently; primarily when it started gettin below 30deg overnight afew weeks ago (soon after Thanksgiving - now). Front diff and T case have fluid
  8. Dec 24, 2016 at 9:38 PM
    CodeSeven
    Serge.
    Coachella Valley
    i suspect a partial clutch engagement. hows shifting? any harder? any grinding more?
  9. Dec 24, 2016 at 9:58 PM
    Ephesians_4_17-32
    Idaho
    '00 Tacoma 2.7
    shifting is fine, both in and out of 4wd. The noise is usually in the first few seconds of 1st gear (from a stop to about 20mph), then all through 2nd, but not every time I drive. It's sporadic.
  10. Dec 24, 2016 at 10:15 PM
    CodeSeven
    Serge.
    Coachella Valley
    huh..... sounds like it has something to do with rubber. whether it be a boot for the cv axle, or a mount or driveshaft support. check their conditions i guess or try and get a recording of the noise as best you can.
  11. Dec 24, 2016 at 10:28 PM
    Ephesians_4_17-32
    Idaho
    '00 Tacoma 2.7
    Awesome, Will do. Thank you for your help; Merry Christmas
    Nutritive likes this.
