4x4 not Engaging
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alexlopez123, Nov 16, 2017.
  1. Nov 16, 2017 at 9:02 AM
    Alexlopez123
    Alexlopez123 [OP] Well-Known Member
    Alex
    2006 silver Tacoma 4x4
    Does anybody know if your speed sensor on each tire have anything to do with your 4x4???
  2. Nov 16, 2017 at 9:36 AM
    Wrench1225
    Wrench1225 Well-Known Member
    jim
    NY
    SR5 4x4 db cab sb
    Rock sliders,total skids,toytec3" lift w adjustable UCA's and O ME,leaf spring pack, w toytec 2.5 rear shocks,diff.drop andBF Goodrich A/T 275 70 R16 (spare fits nicely under bed) Ultra machined Wheels, front camera. Seat covers,Bed liner spray(can't put a scratch in it) currently pricing diff.lockers with heavy duty pumpkin gears. Lastly winch w low profile bumper
    Usually if ECU doesn't know how fast you are going that could cause the 4x4 not to engage. Doesn't have to be all 4 of them one will shut it down. Is the check engine lite illuminated?
  3. Nov 16, 2017 at 9:37 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I was thinking the 4x4 actuator.
    Darth_Yota likes this.
  4. Nov 16, 2017 at 9:41 AM
    Alexlopez123
    Alex
    No but 4x4 will not engage but I took my actuator off n the post where connected so I know my actuator is working fine so don't know
  5. Nov 16, 2017 at 9:51 AM
    Alexlopez123
    Alex
    The first time I used it after hurricane Harvey which I went through a lot of water both my hi and low light where flash that the same time but my 4x4 did not engage
  6. Nov 16, 2017 at 12:15 PM
    Wrench1225
    jim
    NY
    SR5 4x4 db cab sb
    Sounds like the vacuum actuator line.You went through high water and either knocked it off or clogged it.
  7. Dec 2, 2017 at 4:34 PM
    Alexlopez123
    Alex
    Hey man I had a chance to look at my vacuum holes an the one that goes to my tcase was crack do think this where it leaking
  8. Dec 2, 2017 at 4:42 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Is it cracked such that you can't cut it off and still have some hose left to stretch it?
  9. Dec 2, 2017 at 4:47 PM
    Alexlopez123
    Alex
    Yea I got Enough hose to cut it But do you think this might be the problem That it letting vacuum out and not causing it to engage
  10. Dec 2, 2017 at 4:49 PM
    Larzzzz
    Larry
    MA
    I don't know. Go take it for a ride after you trim the hose back to remove the cracked section.
    Let us know the outcome.
  11. Dec 2, 2017 at 4:54 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    On my Tundra, if you have a bad speed sensor, 4wheel drive will not engage.
    I'm pretty sure the Tacoma uses the same system.
  12. Dec 2, 2017 at 5:01 PM
    Alexlopez123
    Alex
    On those speed sensor it just got to be one of them to go wrong for it to not work right
  13. Dec 2, 2017 at 5:04 PM
    koditten
    Kirk
    Central Michigan
    Correct, just takes one.
  14. Dec 2, 2017 at 5:06 PM
    Alexlopez123
    Alex
    Ok I think that might the problem then can I when through a lot of Water in hurricane Harvey And the first time I try to use after that it didn’t work on me
  15. Dec 2, 2017 at 5:06 PM
    koditten
    Kirk
    Central Michigan
    I cut one of the wires that feed the rear speed sensor on my Tundra. 4 wheel drive was not available.
    Soldered the wire back together and all is good.
  16. Dec 2, 2017 at 5:07 PM
    koditten
    Kirk
    Central Michigan
    Check the wires, it's the weakest link.
  17. Dec 2, 2017 at 5:09 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    What vacuum lines are you talking about?
  18. Dec 2, 2017 at 5:12 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Are we discussing the 4wd system in a 2nd gen Tacoma here? Is it not vacuum actuated and the speed sensor is in the transmission not on each of the 4 wheels.
    vssman likes this.
  19. Dec 2, 2017 at 5:17 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Correct!
    Op, I posted basically the same response in your other thread on this issue. 4WD is electrically actuated on the 2nd gens.
    https://www.tacomaworld.com/threads/4x4-vacuum-hose.522378/
  20. Dec 2, 2017 at 5:19 PM
    Alexlopez123
    Alex
    Yea it a 06
