4x4 OR leaf springs and lift blocks and stuff
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by jruiz555, May 21, 2022.
  1. May 21, 2022 at 8:10 PM
    jruiz555
    jruiz555 [OP] Well-Known Member
    2019 tacoma 4x4 OR 5ft bed oem Leaf springs have 30k miles never offroaded great shape, eibach 1" leaf springs has about 100 miles on them. 2020 trd pro ebrake spacer with bolt
    Leafs $140
    Eibach lift block $sold
    Trd spacer ebrake block $20
    Located in Norwalk ca
  2. May 21, 2022 at 8:46 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Pardon my lack of knowledge, I know what the lift blocks are for but what does the e brake block do?
  3. May 21, 2022 at 9:15 PM
    jruiz555
    the ebrake block is for the TRD pro shocks, it moves it away a bit so it wont hit the shock
  4. May 21, 2022 at 9:18 PM
    Tacomike18
    J
    With the 1 in block, is there a problem with the brake line stretching?
  5. May 21, 2022 at 9:25 PM
    jruiz555
    i didnt see any issues when i had the block installed, i had 2020 TRD pro shocks in the rear and the 1" block. I swapped to the icon rxt rear leaf pack and i sorta had to modify my ebrake bracket to fit the leaf. i couldnt use the TRD pro bracket cause my leaf sat differently.
  6. May 21, 2022 at 9:45 PM
    Tacomike18
    J
    I changed to the trd or shocks and did an add a leaf with the extended u bolts but with all the weight the back due to the shell, decked drawers, and tire gate it sits almost level again. I’m in Norwalk also where 605 and 91 meet. I think I can do $60.
  7. May 21, 2022 at 9:48 PM
    jruiz555
    thats cool just send me a msg
  8. May 24, 2022 at 4:53 PM
    jruiz555
  9. May 27, 2022 at 10:33 AM
    jruiz555
    Friday bump
