4x4 problem 05 automatic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skeeter18, Mar 24, 2011.
  1. Mar 24, 2011 at 3:02 PM
    Skeeter18
    Skeeter18 [OP] Member
    Richard
    Pa
    Tocoma
    goes in to 4 wheel drive just fine ,but takes about 1/2 mile to come out while light is blinking when it does come out it bangs
  2. Mar 24, 2011 at 3:03 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    bad transfer case?
  3. Mar 24, 2011 at 3:46 PM
    Skeeter18
    Richard
    Pa
    Tocoma
    only 49k never used 4 wheel drive but 4or5 times per year
  4. Mar 24, 2011 at 3:48 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    X2, the bang is the tension in the front drive line releasing.
  5. Mar 24, 2011 at 3:58 PM
    Skeeter18
    Richard
    Pa
    Tocoma
    tried all the letting off gas stuff
  6. Mar 24, 2011 at 3:58 PM
    CCFBERG
    CCFBERG The Shocker and Me Tall Dark TACO
    Shawn
    LRAFB Arkansas
    2010 TRD 4x4 SR5 DBL cab
    Kenwood 516 DD head unit, Kenwood 12" sub, Kenwood 1800W amp, Brighter reverse light mod, 2nd Air filter ripped out, Tailgate anti-theft. Fog light anytime. Rearview mirror display in HU mod. JBA shorty headers & Catback. K&N Filter. Smittybilt Nerf Steps. Smittybilt M1 Grille. Pro Comp stage II, 6" Lift. 12V Bed PWR. LED interior lighting
    X3!! I do this every time I shift out of 4x4 since the first time I had that "bang" 4x4 disengage. Def doesnt sound like you have an issue just operator error like the rest of us that have experienced this:rolleyes:
    Should it do it...ehh prob coulda been designed a tad different maybe, but once you figure out how to prevent it.....it doesnt matter.
    So..... turn switch to 2wd and let off Gas about half a second later. prob solved.
    If not....after several attempts at this method, maybeeeee and I doubt it.......there is a slight posibility that the front axle diff/transfer case servo(s) is slow.
  7. Mar 24, 2011 at 4:01 PM
    CCFBERG
    Shawn
    LRAFB Arkansas
    OK......I promise you, if you let off the gas too early, your prob will be the same every time. However....is this a new prob? did it just start doing this?
  8. Mar 24, 2011 at 4:17 PM
    Skeeter18
    Richard
    Pa
    Tocoma
    just started about a month ago
  9. Mar 24, 2011 at 5:51 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I find it easier to do when stopped
    put in neutral
    select or de-select 4WD
    put back in gear.
    Also you should be putting your truck in 4WD
    about once a month, even for a short distance
    to keep everything in working order.
    i do mine on the 1st of the month ( easier for me to remember )
  10. Mar 24, 2011 at 6:03 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    The bang is from wind-up. Don't drive on dry pavement, don't switch in and out of 4-wheel while turning the wheel (e.g. going around a sharp curve or parking lot), and don't shift when putting a load on the driveshaft (e.g. going up a hill or accelerating quickly). If you just took a turn that caused wind-up, drive straight for a little bit then disengage and it shouldn't bang because the driveshaft had an opportunity to un-wind.
    However, it could be something more such as low gear oil in the transfer case...check your level too.
  11. Mar 24, 2011 at 6:06 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I put the transmission in neutral and push the brakes quick and it pops out fine. Gotta get the tension off.
  12. Mar 24, 2011 at 6:12 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    Put the truck in N while stopped. Turn to 2wd and sit untill it click out of 4wd. Then if you must, Back up a few feet, then go
  13. Mar 24, 2011 at 6:37 PM
    tinker2
    tinker2 Well-Known Member
    East Of The Big River
    I to have this same problem with my 08 4x4,doesn't do it all the time. Have tried all things suggested, even driving straight before disengagement, sometimes it bangs sometimes it doesn't. I have had problem from new, tech at dealer has heard the disengage prob. no tsb's the only way it doesen't bang is to stop before I disengage 4x4. By the way I'm new here and had just been reading until I saw this. Hi everyone.
  14. Mar 24, 2011 at 7:00 PM
    tinker2
    The bang I hear is very lowd, like something is going to break, then other times I'll just hear a click when disengaged
  15. Mar 24, 2011 at 7:04 PM
    joes06tacoma
    Joe
    Central Coast, CA
    x2
  16. Mar 24, 2011 at 7:27 PM
    megamole
    megamole Active Member
    05 Double Cab longbed Sport Package
    Westin Platinum Series Tube Steps, Westin Bullbar, Full Metal JackRabbit Tonneu cover, 265/70/17 Nitto Terra Grapplers, Removed back seat storage for a Toolbox, Helwig EZ990 helper springs, weather tech floor liners, custum bed lights
    I once had a problem where it would not come out 4x4L it just kept flashing and then beeped at me. I did have a heavy (read overloaded) bed full of fresh cut logs, I was going up a hill coming out of the woods onto the winding road and it would not come out. I tried nuetral, rev, light gas, no gas. It took a min but it was one of the longest of me life (1,000 out of extended warranty)
  17. Mar 25, 2011 at 1:33 PM
    Skeeter18
    Richard
    Pa
    Tocoma
    mine goes to shop Monday Oh boy !!!! made last payment 2 months ago !!! CRAP
  18. Mar 26, 2011 at 8:49 AM
    tinker2
    I wonder what they will find, and what you'r told, let us know will you? :eek:
  19. Mar 28, 2011 at 5:09 PM
    Skeeter18
    Richard
    Pa
    Tocoma
    Front actuator bad $507 plus tax from dealership:(
  20. Mar 28, 2011 at 5:11 PM
    Skeeter18
    Richard
    Pa
    Tocoma
    Will be repaired Thursday I hope
