4x4 Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gieser, Nov 25, 2010.
  1. Nov 25, 2010 at 11:44 AM
    Gieser
    Gieser [OP] Official Flatlander
    MB, Canada
    06 tundra yamaha edition
    scion Head Unit and magnaflow muffler...so far
    ok so just wondering when i engage 4x4 what is the top speed i can go?
    it just says to be under 80km when engaging it.
    I dont want to wreck anything so anyone know?
  2. Nov 25, 2010 at 11:48 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    i don't think there's a top speed.....but you should really be needing it anywhere that you can go that fast
    well i guess maybe a snowy highway but even still you're not going to be driving over 80km/h anyways
  3. Nov 25, 2010 at 12:28 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    I guess you could use it in sand going fast
  4. Nov 25, 2010 at 12:38 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    in 4hi i wouldnt go above about 60 at the very most and usually i wouldnt go but about 40 top speed. in 4lo 30mph is pushing it pretty hard
  5. Nov 25, 2010 at 12:55 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    You can engage 4lo on the fly with the first generations?
  6. Nov 25, 2010 at 12:59 PM
    tmt411
    tmt411 Active Member
    01 4X4 TRD
    K&N Filter system
    For 4 wheel hi the system will beep at you if your are going too fast, for low I can usually shift at 10-15mph with ease
  7. Nov 25, 2010 at 1:05 PM
    vantaco
    no...have to be in neutral to shift over to 4lo
  8. Nov 25, 2010 at 1:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This is not correct. To engage 4Lo the tranny has to be in neutral and the vehicle must be stopped.
  9. Nov 25, 2010 at 2:15 PM
    OffroadToy
    That makes sense. Looking back the post was referring to top speed once engaged.
  10. Nov 25, 2010 at 3:45 PM
    98_Mud_bug
    lucedale Ms.
    i can but i have a manual case, it just grinds a little ha ha
  11. Nov 25, 2010 at 4:24 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    You dont have to be stopped, just going really slow. I believe the little card on my visor says 5mph or less and in neutral.
  12. Nov 25, 2010 at 4:46 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    ^ yah it does say that but it seems like i always get a grind if im not fully stopped in neutral. i dont even try to engage it in when rolling anymore.
    to help answer ur question OP, ive driven on the highway in 4hi when the roads are snow covered or when theres black ice. sometimes up to speeds of close to 100kmh but i never engage it unless under going 80.
  13. Nov 25, 2010 at 4:53 PM
    Avsguy33
    Avsguy33 Well-Known Member
    Most of the time when there is a considerable amount of snow on the ground I drive around in 4 HI and usually dont go over 65 when on the highway. Havent had a problem yet so far.
    In low, I am never out of 2nd gear max. I only use it as a "grab all" gear when I am stuck or pulling someone out and dont want to trash the clutch.
  14. Nov 25, 2010 at 5:03 PM
    Gieser
    MB, Canada
    ya on my way to work the speed limit is 90 and i use 4 wheel drive to get to the highway and when im off it.
    so just stay under 100km?
  15. Nov 25, 2010 at 5:04 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Sry ... I was reading your question to see if I could answer it but I was distracted by your stupid .gif signature. :D
  16. Nov 25, 2010 at 5:07 PM
    Gieser
    MB, Canada
    ya its hard to look at it with a straight face:D
  17. Nov 25, 2010 at 5:09 PM
    Taco-NB
    New Brunswick
    Hmmmm .... Must be a prairie thing!! :D
  18. Nov 25, 2010 at 5:11 PM
    Gieser
    MB, Canada
    you bet :thumbsup:
  19. Nov 25, 2010 at 7:37 PM
    vantaco
    i was using my 4x4 ALOT today to get around in the snow...MT's in snow SUCK huge!!
  20. Nov 26, 2010 at 8:17 AM
    vantaco
    i was noticing that sometimes i was getting a clunk sound and feeling when engaging or releasing 4x4....is this normal?
