4x4 question
Discussion in '1st Gen. Tacomas (1995-2004)' started by tevin, Dec 11, 2009.
  1. Dec 11, 2009 at 8:42 AM
    tevin
    tevin [OP] Member
    Minnesota
    99 tacoma
    Is ok to leave your tacoma in 4x4 mode while driving normally?
  2. Dec 11, 2009 at 8:56 AM
    tevin
    tevin [OP] Member
    Minnesota
    99 tacoma
    well, it's been snowing here in MN and I put my truck in 4x4 to avoid slipping, and I left it in 4x4, while driving to work... he roads aren'tthat bad anymore, Ijust wanted to know if its ok to leave it in 4x4?
  3. Dec 11, 2009 at 9:01 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I would leave it in if you are having issues getting around but as soon as you can get comfortable traction on your drive i would go back to 2wd.
  4. Dec 11, 2009 at 9:02 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    The 4wd system will bind up and be ruined if your use it on dry pavement...especially when making turns. You need to be on a surface that has some give to it like snow, dirt, loose gravel. I've read where some use 4wd when it's raining on paved roads, but I personally wouldn't recommend doing it. In 4hi you can drive close to normal, but if you need to be in 4hi chances are due to the conditions you are going to be going slower than normal (snow, dirt road, etc.) Even while turning on a dirt road you'll experiance some binding while making a turn, so you'll want to make wide turns to help alleviate it.
  5. Dec 11, 2009 at 12:00 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you've got snow on the roads....put it in 4wd and leave it there.
    When the snow is gone, put it back into 2WD.
  6. Dec 11, 2009 at 1:16 PM
    mx04taco
    mx04taco Well-Known Member
    Cory
    Marietta,GA
    04, SR5, TRD, 4wd
    Flowmaster exhaust, Pioneer DVD HU, Pioneer speakers all around, , Viper security w/ remote start, Tinted Windows, Silverstar Headlights, Toytec 3" Coil Springs, All Pro Offroad Diff Drop 3/4", Bilstein 5100s, 2" Toytec AAL's, Toytec poly rear leaf bushings, Deckplate Mod 4", 265/75r16 firestone destination a/t's
    i have seen people literally snap axles doing this, so i would say no.
  7. Dec 11, 2009 at 3:06 PM
    Janster
    Jandy
    Lancaster, PA
    Doing what?
