4x4 red blinking light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Noble4x4, Nov 4, 2021.
  1. Nov 4, 2021 at 6:35 PM
    Noble4x4
    Noble4x4 [OP] New Member
    Jesus
    2013 4x4 auto
    Lift 6” 33”s
    Hello I have 2013 v6 4x4 Tacoma I did a 6inch lift a few months went out this weekend use 4x4 for 30min i see forms to change the actuator but I also noticed a rubber hose (I assume a breather no strapsand dry) above the transfer case that is to short to for the lift is this … could have this been the reason it went it out changing fuild and hose this weekend. As well as the actuator hopefully fixes the problem it 4x4 still engages but is it going out ?
  2. Nov 4, 2021 at 6:41 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If the red light is blinking that is for the rear differential lock system (the 4wd light is green) are you sure you didn't press the switch by accident?
    6 gearT444E and Noble4x4[OP] like this.
  3. Nov 4, 2021 at 6:55 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I bet you pressed diff lock trying to press the fog lights
    Noble4x4[OP] and Dm93 like this.
  4. Nov 4, 2021 at 6:58 PM
    Noble4x4
    Jesus
    2013 4x4 auto
    Lift 6” 33”s
    Lmao I’m dumb guy completely forgot I had that button I was all stressed out even made account but I found the the rubber hose I just buy a longer hose and replace fuild incase any dirt and sand got inside
    TnShooter and Dm93 like this.
